May 09, 2008, 12:13 AM
"It's a Quad" :O
thewz's Avatar
Build Log
RCSuperpowers F-117
2nd build with details pics at post #70
I ordered the PDF planes from Dave and cut this F-117 out and had it built in one night.
HS-56HB servos, 6x5e prop, 1600KV motor, Castle Creations Phoenix 25 Esc, 1300mAh 20C pack.
8OZ AUW
15OZ Thrust
Power Up
May 09, 2008, 12:26 AM
"It's a Quad" :O
thewz's Avatar
Here it is with the guts exposed.
Eclipse Elevon Mix
I plan to add magnets to hold down the cover.
May 18, 2008, 01:49 PM
"It's a Quad" :O
thewz's Avatar
Got to take her out for the first time today.... What a fun fast plane! The elevator feels a little mushy even at speed but I still had plent of control. I wonder if I add elevons to the tail...it would be in the direct prop wash so just a little input would make a big difference or maybe some TV?
It flew right out of my hand just a few clicks of up elevator and I was in business. High-speed turns and rolls are uneventful. Low speed hi AOA is nice and clean with little wing rock. It will fly at 1/5 power at about 1 foot off the ground and make nice gentle turns. Any aggressive input will slow the plane and make a quick plane ground reunion.
I found that if I cut the throttle the plane will pitch forward and roll right. I think I don’t have the empennage installed in correct alignment so when the prop wash is cut the tail rebounds and pushes the plane around. I’ll get a gauge on it and make corrections as needed.
May 18, 2008, 01:51 PM
"It's a Quad" :O
thewz's Avatar
I'll get some better pics today and I am going to start on another build using 6MM Depron from RCFoam. This was built from depapered elmers foam board which is a little less than 1/4 inch and is pretty brittle.
Again what a great plane!
May 19, 2008, 04:38 AM
Just one more flight...
RCSuperPowers's Avatar
Hey alright, sounds like you are getting it dialed in! Great work!
May 19, 2008, 08:50 PM
"It's a Quad" :O
thewz's Avatar
Thanks Dave, this is a great plane and very low parts count to get a pretty scale llike look!
I was nervous on the first launch but after a few seconds I was just having fun!
May 19, 2008, 09:11 PM
GO FAST OR GO HOME!!!!!!!
thewz it looks good.
May 19, 2008, 09:17 PM
"It's a Quad" :O
thewz's Avatar
Thank you. The next one will be made of true 6mm depron without the KFM step on bottom. I'm looking for more speed....
May 19, 2008, 09:51 PM
ur welcome and you that should make it alest a lil faster right? i was looking at this kit befor i saw one on parkjets.com and downloaded the plans. i just hope mine flys its alot of hard work.
May 19, 2008, 10:31 PM
"It's a Quad" :O
thewz's Avatar
I got the plans from Dave at RCSuperPowers for $9. There are only a few parts to glue and cutout and you still get a good looking good flying model.
If the free plans version doesn't fly well I would recommend getting this one from Dave.
May 19, 2008, 10:46 PM
yea thats what i tought too. but it should
May 20, 2008, 02:06 PM
I bought the 9$ plans also. I have not had a chance to build it yet. Im going to go a little further and bevel all the angles for a clean look.
The free plans are nice but alot more complicated and I read a bear to get fine tuned, but is way better looking.
I'm going to build the RCSuperpowers version because its so easy to build and fly.
May 20, 2008, 10:02 PM
"It's a Quad" :O
thewz's Avatar
I'm doing the nice bevels on the new one as well.
This version both looks good and flies great!
May 21, 2008, 04:05 AM
Cant you feel the freedom
NuttyPro67's Avatar
What did you guys with the RCPowers plans think of the assembly instructions on page 2 and the simplicity of the plans? Do you have any suggestions for improvement?
May 21, 2008, 10:08 AM
"It's a Quad" :O
thewz's Avatar
The plans are very easy to follow and the photo references are very helpful. I did find that I needed to angle the slots some to allow the upper fuse and ducts to sit correctly but it's not critical. After my first build I am also going to angle the bottoms of the fuse and ducts themselves to allow more contact with the wing and have a cleaner look. I’m also going to make a small guide to go between the vertical tails to keep them in alignment with each other and therefore keep the empennage truer.
Mini-Review RCSuperPowers F-117 Stealth Fighter jetset44 Pusher Prop Jet Models 941 Jan 05, 2011 09:59 AM
F-117 Ducting ??? ESB Electric Ducted Fan Jet Talk 17 Mar 10, 2009 08:54 AM
Modelair-tech F-117 Nightstick knight of Ni Parkflyers 16 May 20, 2008 06:58 PM
F-117 Nighthawk LuckyArmpit Foamies (Kits) 4 Jul 24, 2002 08:23 AM
