May 07, 2008, 02:45 PM
AP-stick
ggtronic's Avatar
Video
pulling shark--never seen something flying so slow !
the "pulling" SHARK...
https://www.rcgroups.com/forums/showthread.php?t=859304
slowest flyer around ? not as much as Easyrydr biplane
but still the slowest single wing
May 10, 2008, 05:11 PM
bass3587's Avatar
Nice vid and smooth little design. Thought I would at least post a comment after 114 views.
May 10, 2008, 06:40 PM
flying with dx7...
futabafreak's Avatar
I like it but I dont think its that slow???
May 10, 2008, 10:43 PM
AP-stick
ggtronic's Avatar
bass3587 thanks
futabafreak, your right
http://ggtronic.dyndns.org/~ggtronic/1/slow_shark.wmv
watch this one...
how could i compare ? i need a radar reading while flying slow !
--the plane run at 5oz loading per square foot
--it use the highest lift type of wing:
http://acam.ednet.ns.ca/curriculum/wing.htm
unless they hovering, i dont think that most of other type of
wing can compete with Deep Chamber-High Lift-Low Speed-Thin Wing Section-Good For Transport, Freighter and Bomber Planes ?
May 10, 2008, 11:41 PM
N.F. Dawn Patrol
My e-flight Jenny is slower. In a small ammount of wind i can make it stand still. %to 7mph and i can make it go in reverse!
May 11, 2008, 07:11 AM
AP-stick
ggtronic's Avatar
i agree ! didnt know this bird, same weight than mine (8oz)
http://www.amainhobbies.com/product_...ducts_id/20710
same wing configuration X2
E-Flight Jenny flies (6 min 25 sec)
i can also stand still with low wind when i use
my 2s700 lipo...but i let you win anyway
only one problem for us, AP guys (aerial photography),
its hard to find a good spot to locate a camera on your
biplane ?
May 11, 2008, 10:26 AM
N.F. Dawn Patrol
Tis a good plane. I use a e-flight 800 mah pack in mine. with no wind i can fly her at 1/4 to 1/3 throttle for 18 to 22 minutes. I also added about 1/8 oz weight to the nose because at anything over 1/3 throttle she climbs straight up.
May 11, 2008, 06:42 PM
flying with dx7...
I mean I had a powered glider that would do like 9 mph and stay up it was so light and
than again its the slowest I have ever seen but there's got to be some one out there thats saying well Ive seen a plane slower than that, thats not a slow plane...you get the jest.
May 12, 2008, 01:57 PM
You might have a thrust angle problem. If the tail is dragging in slow speed, but not high speed I would imagine a CG issue. If the plane goes verticle with higher thrust it is probably a thrust angle/trim issue. I had the exact same problem with my SE5a by Tony65x55, once i corrected that she flew great.
May 13, 2008, 08:08 AM
yup, tail-heavy
could be a bit heavy in the tail...thrust angle maybe, also,if straight up at throttle. nice plane, trim that baby out,boy. Al
May 13, 2008, 02:25 PM
AP-stick
ggtronic's Avatar
new video "on the air"
--2/3 throttle is needed to run at 385g AUW...
sorry for the poor quality, the file uploaded is 52 meg and nice,
but online result is not so good
ggtronicAPhd (2 min 17 sec)
Build Log --APstick--240g AUW--good trainer- ggtronic Foamies (Scratchbuilt) 15 Sep 26, 2009 01:09 PM
Video --PULLING SHARK--thrust bench test ggtronic Electric Plane Talk 0 May 04, 2008 09:50 PM
