Sep 03, 2006, 10:58 AM
Magnum 4 by Tanic Packs
Well if at first ya don't succeed try try again and this time I think we finally have it right. This is our 4th Magnum plane and our 6th fast plane for the year and trouble has followed us with the rest. This time I believe we have it figured out. This new plane has many upgrades starting with the Neu 1521/1.5 motor, this is a 3000 watt motor rated at 60,000 rpm and of course we are pushing that a bit as well. Here are some stats on this :
Neu motor 1521/1.5
Tanic 9S 4350 lipo pack
Castle Creations HV 85 controller
Hercules HBEC ( up to 11S and switchable 5 or 6 volts)
Berg 7 rx by Castle Creations
6 x 9 APC prop
Performance numbers:
RPM in excess of 32,000
Watts in excess if 3400
amps 102 +
thrust 288 oz +
estimated speed 220+
Plane weight 5 1/2 pounds
We will have this bad boy at the NEAT Fair and will be flying it at 7:00 am Friday morning, figured we'd wake up some campers!
This plane is a real screamer !!!
The performance #'s are actual as tested not calculated
Sep 03, 2006, 11:43 AM
Use the 4S Luke
feathermerchant's Avatar
Outstanding Brian! I have some of those 4350's and they're great!
Do you need that much throw on the elevaor?
Sep 03, 2006, 12:16 PM
turn, turn, turn.
Kenny Sharp's Avatar
Good.
I'd like to see something else besides TP.
Sep 03, 2006, 12:17 PM
we have about a 1/2 inch mainly for rlanding because as we slow down we need more throw, in flight the surfaces hardly move the plane lands very fast
B
Sep 03, 2006, 12:21 PM
ya these cells will hold around 3.7 volts per cell at 100 amps this whole system is really not over worked and should actually last for awhile.
Dan Landis will be piloting this thing at NEAT he blew up one of the first ones at AZ last year great recovery and landing though.
Brian
Sep 03, 2006, 02:11 PM
DS JUNKY
Looks like a lot of power but the plane looks incredibly draggy. Even with 3500 watts I really can't imagine it going anywhere near 200mph. I had 2000 watts in the trick which was a FAR FAR FAR more streamlined airplane and that was only doing high 160's low 170's out of a dive and 150's level. You need to get a radar gun out there and see what you are really looking at. Keep in mind the TheTicks' F5D nemesis with 1500 watts and razor thin and short arrow root nwings and narrow fuse barely wide enough to fit the 1509 with no heat sink would barely break 200mph. The next step up to a more draggy plane (the vandetta) which still was very aerodynamic etc needed double the power to go 200mph.
Sep 03, 2006, 02:48 PM
we dopplered the last plane at 176 ya I know doppler is not all that but,,,,,,,,,
we will see
B
Sep 03, 2006, 02:55 PM
eflyguy
Andy W's Avatar
"tp" - tanicpacks?
..a
Sep 03, 2006, 03:15 PM
turn, turn, turn.
Originally Posted by Andy W
"tp" - tanicpacks?
..a
In Kens' world, Thunderpower is the only battery that exists.
Sep 03, 2006, 05:36 PM
Need 4 Speed!
pdawg's Avatar
Looks great! I'm sure 30,000+ rpm is the perfect wake-up call for a fly-in. Whatever the speed, this is all really just a work in progress . Nothing is ever really fast enough for speed freaks. Go get'em Brian
Latest blog entry: original Y/A F-18 Kit
Sep 03, 2006, 05:41 PM
Size Matters!
RocketRob's Avatar
Looks like fun Brian......go fast or burn!
Sep 04, 2006, 11:04 AM
Castle Tech
Joe Ford's Avatar
Only question I have Brian is when do I get to fly it?
Sep 04, 2006, 11:57 AM
Any time Joe !!!! i just boxed it all up and it's on its way to Dan tomorrow, hopefully it gets there in one piece!!! Are ya going to be at Neat this year??
B
Sep 05, 2006, 10:07 AM
Caution:Makes sharp left turns
Troy's Avatar
You will pick up an easy 10-20mph if you close up that slimer garage. Just make sure you get video
Sep 05, 2006, 10:57 AM
ya I know but I want to see the temps after the first few flights
B
For Sale 2 Tanic Packs and 4 Balancing Chargers chadvicki Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 09, 2006 11:22 PM
$52 - 4 Qualcomm QC830 packs and 2 Car Chargers asperkins Aircraft - Electric - Airplanes (FS/W) 4 Aug 15, 2002 02:15 PM
The Ultra Mk 4 by Aveox advice ricks3 Electric Sailplanes 8 May 02, 2002 12:45 PM
Sale on 2100 4/5 Sanyo packs.... sjslhill Aircraft - Electric - Airplanes (FS/W) 4 Mar 11, 2002 12:47 PM
2100 4/5 Stick Packs are in stock sjslhill Aircraft - Electric - Airplanes (FS/W) 0 Sep 27, 2001 03:47 PM
