Question
Anyone succesfully built a wired IR repeater?
Pretty simple, really. Just looking for someone who's actually built one that works. I'm leaning towards this one..
Thx! ..a |
I've built so many versions of these in the past (home automation projects) and eventually decided on using a commercially developed one... simply because it was occasionally flakey and picked up ambient noise/interference. Here's a few circuits to ponder too... (maybe you already seen these...) the better ones attempt to filter out surrounding noise (i.e. ambient light, etc...)... and be sure to use some small plastic (dard-reddish looking) IR filter on the receiving detector... it will help in most cases: http://www.cedarnet.org/smartware/Hardware/IR_Repeater/ http://www.zen22142.zen.co.uk/Circui...face/irext.htm http://www.electronics-lab.com/proje...003/index.html http://www.electronics-lab.com/proje...008/index.html Also, instead of running extra wire to extend a wired IR system, you might want to look at Xantech products,... as they alllow you to pass IR signal info down an existing coax cable (i.e. cable/satellite TV) using special modulators/demodulators. http://www.xantech.com/Infrared/Infr...ROverCoaxKits/ There are other off-the-shelf kits like this that allow you to use existing CAT5 and/or coax... |
Thx! I'm only running it into a cabinet, I've converted an old TV cabinet into a widescreen HDTV. Just have to put some trim on the front, waiting to see how the IR can be done first..
..a |
Yup, I built one a bunch of years back too. As I recall, I used an IR module like this one to trigger a 555 based 38 khz oscillator driving an IR LED. That way the photo diode didn't have to be right up against the remote.
Dan |
He he..
In this case, the "furniture" is junk made from particle board with a laminated finish, that is chipped and weathered. That said, we don't want a modern stand in that room, so it works nicely. #$#%$#@#@ comcast showed up 2hrs late with broken, used equipment. Told them to go $#@$@#$ themselves. Trying to figure out what to do. We're surrounded by trees so existing DirectTV reception is unreliable, especially in weather, and moving to HD will cost us plenty as we're existing, not new, subscribers. I've signed up for Dish to come out and I'll get lots of new equipment, but I am pretty certain they'll say they can't install with all these trees around. UVerse is in Atlanta but not around here yet. ..a |
Do you have an outbuilding (garage, shed, etc) that has a clear view to the south, then run a buried cable to the house. Is there anywhere on the property with a view to the south where you could mount a dish on a pole? Maybe a larger dish would give you enough signal through the trees.
Dan |
Nope - at least, not close enough to be viable. We live on a hill that drops off to the east, and all the required satellites are west (207-254 degrees).. the DirectTV we have now is peeking between a gap in the trees which vanishes in heavy rain or strong winds.. For HD, we need more than one satellite, which is impossible. Also, Dish's satellites are lower (~35 elevation vs 46 for DirectTV that we have) which makes it harder..
Trust me, I've walked around the yard with a finder forever trying to find a location.. Darn I wish uVerse would come by here soon... ..a |
Not too sure of your situtation there but a friend of mine did just this... and it's worked for several years now (needs occasional tuning):
http://www.ehow.com/how_2001254_moun...-top-tree.html |
Thread Tools | |
Similar Threads | |||||
anyone ever built a laser cutter? | jbourke | Laser Cutters | 15 | Jan 10, 2013 03:56 AM | |
Anyone ever built a electric version of 1/2A .049 A-10 from 1992 Model Airplane News? | GWhaling | Electric Ducted Fan Jet Talk | 1 | Oct 08, 2003 06:07 PM | |
Anyone else built the Zero-Seven as an electric ? | robertc | Sport Planes | 9 | May 18, 2003 06:30 PM | |
Anyone ever built a JK Aerotech plane? | squelchF18 | Electric Plane Talk | 6 | Apr 27, 2002 09:04 AM | |
Has Anyone Ever Built One of These? | Acer | Electric Sailplanes | 4 | Dec 02, 2001 05:38 AM |
