F-15 EAGLE in "Five Easy Pieces"
With my F-14 Tomcat looking on from it's perch on the Hi-Tek balancer my F-15 EAGLE FEP Pattern takes shape in half form on the cutting table.
It is 42" long with a 28" wingspan. Elevon set-up like the F-14. micro-jet power. |
Now rendered in Blue core fanfold.
42" long with a 28" wingspan. KFm4 wing. 2200kv motor, 6x4 prop, 20amp ESC. Two MG servos. GWS mixer. 1600mah Li-Po. |
This Five Easy Piece F-15 EAGLE has the same kinda tail-feather set-up as I did on the FEP F-14 Mach TOMCAT.
Carbon Rod and straw hinge. Also a KFm4 wing. I need to correct some pattern flaws before I can pot a PDF of her. I over cut the motor slot, oversized the forward nacelle pan and undercut rh main wing to fuse slot. I'll have all of this fixed when I post the pattern on my media-fir site later. |
Here is the "Five Easy Piece" F-15 EAGLE PDF pattern link.
http://www.mediafire.com/?8y7qq1spxfbwpi6 |
An old buddy stops by to watch me fly the Eagle.
An earlier Eagle Sortie before bad weather.
She is so balanced that I can put her in the air at 40% throttle and she will just fly away twelve feet or so from the ground straight and steady and I do not even touch the controls till it's time to bring her back around at the end of the field. |
Discussion | Five easy piece f-14 tomcat | bobdaeronort | Foamies (Scratchbuilt) | 80 | Oct 25, 2012 05:43 PM |
Sold | Regal Eagle F-15 with Robart retracts | Green Fuel Boy | Aircraft - Fuel - Jets (FS/W) | 5 | Feb 28, 2012 11:31 AM |
Sold | E-flight F 15 Eagle RTF | HUGH DURDEN | Aircraft - Electric - Airplanes (FS/W) | 3 | Oct 10, 2011 08:06 PM |
Sold | Sunset Models F-15 "Sport Eagle" Jet | Jetnfast | Aircraft - Fuel - Jets (FS/W) | 5 | Oct 07, 2011 05:43 PM |
