Apr 20, 2012, 12:43 PM
nph
nph
Where to buy High start rubber
I saw Hyperflight in the UK are selling a small High Start Rubber kit. But I would like to buy it here in the US to reduce freight etc.
Any suggestion on where I can find it?
Apr 20, 2012, 02:24 PM
Dragons, WindMills, all Same
jcstalls's Avatar
The Best.
Hosemonster
http://www.aerofoam.com/products.htm
Apr 20, 2012, 02:37 PM
Tuomo's Avatar
We use Thera Band. Simply buy the thickness you like best. It readily available and same material as EMC-Vega Megarubber (the best stuff).
Apr 20, 2012, 02:53 PM
Woodstock 1's Avatar
Where do you buy Thera Band?
Apr 20, 2012, 03:00 PM
Tuomo's Avatar
Is is sport equipment. Just use google and by from the most convenient retailer. Very easy to get.
Apr 20, 2012, 10:13 PM
Avaldes's Avatar
Mark Mech is THE source for high performance histarts. I just got one from him and I am very impressed with the quality of the materials. Worth every penny to have a complete histart show up in the mail.
Apr 21, 2012, 06:43 AM
Dark Side of the Red Merle
Curtis Suter's Avatar
Originally Posted by jcstalls
I'll 2nd, 3rd and 4th Hosemonster! I've had one for over 15 years and still going strong!
Curtis
Apr 21, 2012, 09:14 AM
Win=span\massXpractice+lu ck
webbsolution's Avatar
absolutely! Hosemonster at aerofoam rocks - ill put thier product up against theraband in a life span contest - the aero product is designed with UV inhibitors - leave em both in the sun for a few seasons and compare.
Apr 21, 2012, 09:20 AM
Thanks Tuomo. I had a look, not that many suppliers to Ireland, and not cheap. But good latex rubber is probably never cheap I guess.
Apr 21, 2012, 09:22 AM
Originally Posted by webbsolution
Hosemonster at aerofoam rocks .
That's fine, but I wouldn't like to be asked on the field which make of rubber I'm using !
Apr 21, 2012, 11:34 AM
I think that depends who is asking you does it not? I got asked that question at the SWC this year and I guess she liked my answer...see picture
May 15, 2012, 03:25 PM
Proud member of LISF and ESL
I used to recommend the Pinnacle Hi-starts from NESailplane, but since they closed, Hosemonster is getting my recommendations.
http://www.aerofoam.com/highstarts-bungees.htm
Hobby-Lobby's rubber has gotten good recommendations in the past as well.
http://search2.hobby-lobby.com/psear...d=2&q=hi-start
May 15, 2012, 03:50 PM
I went with Hosemonster, and I was very happy with the service I got from Mark.
May 15, 2012, 03:58 PM
FWIW, we did a pull test on the 3 meter rubber. At 3X stretch we were getting 19 pounds of pull which is plenty to launch anything up to about 4.5 pounds with a solid launch or 6 pounds with an adequate launch. Add a little breeze an they really go up!
May 15, 2012, 04:00 PM
Where did my plane go???
HHARRIS's Avatar
That was my finding as well.
I purchased the 4 meter high start kit. I only use half of the 100ft rubber part and 200ft of the 500ft line. It puts my 3.5 Xplorer up higher than I need. I ended up selling the other 50ft of rubber as there was no need for it.
HUGH
Sold Hosemonter 2M High-start (100' of rubber tubing) RCPC Aircraft - Sailplanes (FS/W) 4 Jan 16, 2012 07:10 PM
Discussion patching black rubber high start? balsabozo Thermal Soaring 2 Oct 29, 2007 03:34 AM
Question where to buy a good high start nitrobass180 Sailplane Talk 15 Apr 10, 2007 09:00 AM
Question high start rubber jackandmusa Sailplane Talk 3 Feb 23, 2007 09:59 PM
Wanted Meduim high start rubber Speedo125 Aircraft - Sailplanes (FS/W) 2 Mar 14, 2006 07:20 PM
