Nice puzzle without manual but next time make more parts that i have more time to play.
Some shimming is needet to get a it play-free but it is feasible. On the roll shaft 4 aditional washers between the bearings are needet for a friction free run. Over all it looks very solid and reasoned. When i have found out how to mount it on my DIY LG i will make a mirrorvideo. To be continued........ Greetings Teramax ps.: OZ, there´s no screw long enought for roll axle in the bundle. |
I noted short screw matter,yes you are right,there are 4x45mm and 1x40mm screws,40mm is not enough I changed short roll shaft,too. Part list changed after your assembly,thanks. Waiting for some video shots. best regards Ozan |
hi.. anyone have a test flight with a ThreeDee 3 Axis Gimbal on a hex setup? how it performs??? and does it include its own gimbal control at 499$? or need to purchase separately? and what gimbal control is recomended and tested? im interested to this. i plan to mount it on my octo.
Aluminium tubes diameter is 16mm. you can replace them with carbon fiber,carbon tube version will be ready,soon. |
Ok then I'll buy it next week. I think the pulley are not included ?? that why you ask client to choose between Futaba and Hitec mounts ? Which maximum weight can it take, i mean what would be the most heavy reflex i could put on it ?? 1kg ? |
with 3:1 ratio and hs5565 servo,you can use cameras up to ~1.5kg. |
anyone sample video of ThreeDee 3 Axis Gimbal using the gimbal control??
Discussion | A new professional camera gimbal (tongue in cheek) | SeismicCWave | Multirotor Drone Talk | 23 | Nov 13, 2011 01:48 AM |
Discussion | What gyros to use on a 2 Axis camera gimbal? | Voguna | Aerial Photography | 0 | Mar 13, 2011 11:51 AM |
