Technically, you could upload history to your BT/LE-enabled smartphone (or any other device) and sync it to DropBox for viewing on the iPad 2nd gen, but we can't guarantee support/performance. If you already purchased the app for another Apple device, then there's no cost in trying to see how it works on other older Apple hardware, but we won't be putting resources on fixing bugs that are specific to older hardware. |
Do you see any popups on the Bump Controller about "Bluetooth connecting" ? By "won't connect" do you mean you see it in the list when you Scan, but aren't able to connect ? .... or it doesn't show up at all ?? |
I assume you're running latest firmware on both Bump and Powerlab ? |
I was kinda hoping that the 2nd gen would work - bugger. Oh well, I do have an android tablet that will work so I guess I'll pay for the android app as well. |
It show up but doesn't give the option to connect.....that's ok I just have to either used my iPhone or bring my 12" iPad Pro..... |
// Version 4.02 // BUGFIX: New BumpTag wizard sometimes fails to write tag // // Version 4.01 // FEATURE: Version number synced-up with latest Android "universal" app version // FEATURE: Cycle graph export to CSV (to DropBox /export directory) // |
Let me know if you have any problems. NOTE: Version 4.x is only supported on Android 5.0 and later. Older devices will only be able to access the existing version 3.50. |
Kelly,
I installed Android CCS v4.04 on both my Samsung Note 10.1 (Android v5.1), and on my Samsung Note 4 Android v6.0.1. The CCS does NOT turn on the BlueTooth xmitter like it did before. If I turn on the BT, the CCS will scan, but never finds the Bump Controller. Gus... P.S. What is the best way to capture the "Error Log" , and to transmit it to you? |
Reason: Add Text.
Wow new version looking v. slick! Hope to see more things added too Issues so far:
-Exit/disconnect is broken. More than once, neither choice in dialog works. Home only way to exit. (Now next day I re open app, still stuck on dialog. Had to Force Stop app.) -Stuck at 'scanning for bluetooth' on app restart even though it was connected a few min. earlier and nothing on BC side changed. Had to do Force Stop on app. -New tiny font shows all history menus properly now (nice) but then is too small on main display. Voltages etc. were much more readable on previous ver., using average size smartphone. -History lists are very sluggish - almost not usable. My phone is not high end at all, but has no problem w/previous ver., and other apps. |
The failure to disconnect/close is causing the failure to scan. Can u take a pic/screenshot of the Debug log after app is reopened after disconnect ? |
For now, just take a pic or screenshot of the Debug/Error log and post. Eventually it will have option to post/email directly from app but that is surprisingly hard to do in the app framework i'm using. |
This morning I have been able to talk to both Bump Controllers with my Samsung SM-N910A Galaxy Note 4 Phone. I still have to turn the Blue Tooth transmitter on before trying to connect, which was previously not the case. I am still trying to get my Note 10.1 (Android v5.1) tablet to connect. I will let you know how that works out. Gus... I am now getting as far as receiving the message "Pairing Rejected" when trying to connect to my Note 10.1. Gus... |
Reason: Update Information
