Jan 22, 2013, 11:58 AM
robj's Avatar
Warm Welders glue drips and flows real easy. Makes a nice gussett.
Jan 22, 2013, 01:23 PM
I fly, therefore, I crash!!!
SteveT.'s Avatar
Or epoxy brushed on using "acid" brushes found at hardware stores, used to put flux on copper pipes while soldering. Stick the brush on a piece of wooden dowel rod and brush it along the spars/wing tube in the wing. If you want, you can thin the epoxy using isopropyl alcohol that you can also buy at a hardware store...(not rubbing alcohol, as it has too much water in it)....
SteveT.
Latest blog entry: My old shop....
Jan 22, 2013, 03:36 PM
AeroTripleThreat's Avatar
SteveT.
Excellent guys thank you !! I will have to try that..
Jan 22, 2013, 07:48 PM
SteveT.'s Avatar
So....like I said when I first flew my 74" Edge with the Hacker A60-5S on 8S.... "OH HELL YESSSS!!! I flew my Extra today for the first time with my A60-5S in it, and it is GREAT!! Plenty of power balances perfectly, pulls out of a hover very well, and on a five minute flight, with lots of verticals etc....only took 50% out of the Thunder Power 4S 45C 4400mAH packs (X2 for 8S)!!!
SteveT.
Jan 22, 2013, 08:13 PM
rayonnair's Avatar
Nice. I guess that means 7-8 minute flights are totally doable. Is the power ballistic, or just "plenty" powerful?
In the other thread there is talk that the slow boat has arrived. Hopefully there are some 72" extras in there. *Fingers crossed*.
Jan 22, 2013, 08:43 PM
SteveT.'s Avatar
1/2 throttle the plane was ripping across the sky, and verticals were out if sight. Granted it may not be enough for "some" people but then 5000 watts would not be enough for them...
SteveT.
Jan 22, 2013, 11:43 PM
rayonnair's Avatar
Woo. Sounds like fun. Ok back to the agonizing wait for me
Jan 25, 2013, 01:07 AM
If it flys, I like it
Heirmeistr's Avatar
Let us know how it goes SteveT! What prop will it be turning? The specs on that A60-5S look similar to the motrolfly 5320/300kv I got. I'm going to start with a 19x8 on mine.
Man, I've only been waiting for a month and it's still excruciating. I can't wait for the container to arrive so my airframe can get shipped.
I bought the Hacker A60-5XS at the AMA show 2 weeks ago and they recommended a 18x10 or 17x12 prop. I also bought the servos and everything else I will need. Now I just need the plane!!
Jan 25, 2013, 01:33 AM
SteveT.'s Avatar
5S and 5XS are two completely different motors. 5S 295KV, the 5XS, 420KV. Personally, I wouldn't use that motor in a 72" Extra unless you are just wanting to scream around the sky. I have it in my 70" Velox, but I used it in that plane to give me the ground clearance for the prop in the Velox, and it is killer in that plane (though I believe I am going to go down to an 18X8 prop). However, this is just my preference. YMMV....
SteveT.
Jan 25, 2013, 01:44 PM
Alex Schauer's Avatar
Whats the motrolfly motor of choice for this one?
Jan 25, 2013, 01:46 PM
Depends.. If you need the weight up front is the motrofly 5320 300kv. The other motor choice is the 4320-300.
Jan 25, 2013, 02:05 PM
robj's Avatar
IMO, heavier. I also run 8s, i didn't like mine tail heavy.
Jan 25, 2013, 02:23 PM
Barefoot Birkinsomething
rcbirk21's Avatar
have to say after watching wamsy's video and talking to him, the 4330 would be perfect, 4325 would be the lightweight choice. 4320 too light IMO
Jan 25, 2013, 02:34 PM
Irg
Irg
ol' yellow eyes is back
Irg's Avatar
agreed, the video speaks volumes. if my ol' A5012L ever craps the bed I'll likely do the 4330.
Jan 25, 2013, 03:18 PM
I also went with the heavier setup of 5320 on 8s. Wamsy setup is also nice and he throws it around with that motor.
Build Log 3D Hobby Shop 57" Extra 330 SC -Build Thread- flyinhigh025 3D Flying 14466 Oct 07, 2021 08:49 AM
Sold 3D Hobby Shop 47" Extra SHP V2 ctraut5 Aircraft - Electric - Airplanes (FS/W) 3 Sep 20, 2009 12:08 PM
Sold 3D Hobby Shop Extra 300SR silent_guru Aircraft - Electric - Airplanes (FS/W) 8 Sep 19, 2009 02:21 PM
Video 3D Hobby Shop 103" Extra 330 SC sukhoi26mx Fuel Plane Talk 7 Feb 27, 2009 09:37 AM
