Sep 16, 2012, 08:56 AM
Always Indecisive
electricrc68's Avatar
Originally Posted by NitroCharged
Not long. It's a small lipo and going to 3S sucks the juice.
Going back here, would you say the flight times are around 3-4 minutes?
Sep 16, 2012, 04:58 PM
Team30 Micro EDF
NitroCharged's Avatar
No, full throttle and you'd get around 2 minutes on the 180.
Sep 16, 2012, 05:27 PM
Always Indecisive
Oh okay thanks. Guess im going to just use 2s in there.
Sep 17, 2012, 03:31 PM
Anything that gives me a High
super kupfer's Avatar
Question: two of my friends just purchased sabers, while flying they experienced signal interference but only on the throttle between themselves, they both fly JR, did anybody have/had this phenomenal happen to them?
Sep 17, 2012, 03:47 PM
Heli collector
livonia bob's Avatar
Must be a common problem as this is the third time I have read about it on three different threads.. In the past two minutes..
Sep 17, 2012, 08:47 PM
3d astronaut's Avatar
Were they using the "Anylink"???
Sep 22, 2012, 09:26 AM
Always Indecisive
Hey guys. Are the stock 2s 250mah 20c batteries that come with the F86 sabre good for the plane, or is there another 2s battery i should look into for the F86 which will give me more flight time and performance? (don't have the plane yet, just doing some research first).
Sep 22, 2012, 07:41 PM
Team30 Micro EDF
The 250's balance the jet out without having to add weight. The model was designed to carry them, so they are ideal to use. They give good flight time.
Others are using slightly larger lipo's like 300mah size but you have to make sure it's balanced. A small error in CG will upset tiny models a lot.
Sep 22, 2012, 07:49 PM
Heli collector
I have flown mine with Nano-Tech 300 and some 400's.. The extra weight makes doing scale like landings hard as it doesn't like to flare.. If you are flying without the wheels and landing on high grass then this isn't much of a problem..
But the 250's seem to be the perfect battery weigh wise..
Sep 22, 2012, 08:44 PM
Have flown Zippy 350s. About as big as you can get.
Also tried one of these noname batters. I like it. Maybe slightly smaller than the zippy but heavier than stock 250. Would say I get about 5-6 min flying time, maybe more without pushing it.
http://www.ebay.com/itm/Li-Po-Batter...311#vi-content
Sep 22, 2012, 08:52 PM
Re: What to do with F-86 electronics & EDF?
Have a fairly well worn F-86 and was thinking of putting the and EDF into something else. Has anyone tried to build anything with the stock F-86 electronics?
This Techone Mini F-35 seems like it might be a good candidate. Has anyone tried?
http://www.44ghz.com/techone-mini-f35/#!prettyPhoto[ajax]/6/
Sep 22, 2012, 09:45 PM
Team30 Micro EDF
I tried it on a 27mm about 3 years ago.
Team30 Micro EDF F-35 with Turnigy 10mm inrunner (1 min 52 sec)
Sep 22, 2012, 09:53 PM
QuAd FaNaTiC
Razors edge 29's Avatar
No Mylar
Staples didn't have anything
Only think I could find was at craft store and its like overhead clear sheet but too thick and heavy.
So
Will have to look elsewhere dagnabit
Sep 22, 2012, 11:47 PM
3DHOG
jcdfrd's Avatar
I thought guys were adding a dime to the battery with the stock 250's to get better cg? I ordered some turnigy 1s 350 cells and made my own packs.....so 2s 350mah 20c and they came out 3 grams heavier than the stock 250 and it balances and fits perfect
Sep 23, 2012, 12:07 AM
Team30 Micro EDF
No, it's the first batch of jets that came with a 200mah lipo that needed the dime under the lipo.
New Product Sabre Jet F86 30mm EDF by Great Planes..TX-Ready (TX-R)..or RTF Version 15'' WS modfly Micro Ready-to-Fly 151 Dec 20, 2012 09:20 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
