Jul 31, 2012, 08:32 AM
3D for Me
JC Spohr's Avatar
Has anyone that has flown the plane taken any measurements for the control surfaces?
What degree of deflection for full throws?
I stopped building mine at the point of cutting in the aileron servos because I think the MG-14's with stock arms yielding only 20* of aileron is not enough.
May not be enough on the elevator either.
I'm thinking a change to larger servos (aka Twisted's 18g) and extended arms is in order.
JC
Jul 31, 2012, 09:04 AM
Limb stalker
Parksinatree's Avatar
I increased the aileron throws on my transmitter to 150% with HS65 MG's. MUCH better. I don't have a throw gauge but I'm guessing I get at least 30 to 35 degrees now. My servos are mounted vertical. I wonder if you would get any more throw mounting them horizontal?
Jul 31, 2012, 10:34 AM
Don't give in to gravity
Gravitycheat's Avatar
JC
More aileron deflection would be nice even tho mine is doing some nice 3d with the standard arms that come with the th 18.8 gram servos
The elevator is fine with the 18.8 servo and the long servo arm that comes in the kit.
Il post some video tonight and it will give you an idea what the standard set up will do
Jul 31, 2012, 10:38 AM
3D for Me
JC Spohr's Avatar
Thanks.
What battery are you using, 1800 or 2200?
Jul 31, 2012, 11:44 AM
Thanks.
1800 but plan on running 2200 ad well
Jul 31, 2012, 06:33 PM
Some fun with the Sbach
Shawn DuBois Flying the Sbach 48.8 inch EPP by RC Factory (4 min 56 sec)
Jul 31, 2012, 07:12 PM
toolman18's Avatar
Nice video Shawn! You Rock! Enjoyed the music.
Jul 31, 2012, 07:17 PM
3D for Me
JC Spohr's Avatar
https://vimeo.com/46719396
NICE!
Q1: Were you really running a 10x4.7 prop as stated at the end of the video??
Q2: CG at 100mm?
JC
Jul 31, 2012, 07:25 PM
NICE!
Q2: CG at 100mm?
JC
I was running a 10 x 4.7. I had to small of a motor on it and was running an 11 x 7 and the motor was burning up. so to be able to fly, i put a 10 x 4.7 on so i did not burn up the motor. i have the right motor coming. Was just bad motor planning on my part.
My CG is closer to 105 or 110 and seemed to be balanced well. I still only have 5 flight on this bird and will better know my Cg liking after a weekend of flying the Sbach. I'll let you know.
Thanks Brad. and thanks for all your help with the video!!!!
Aug 01, 2012, 01:36 AM
Aviefly's Avatar
Good going Shawn, I enjoyed that. Didn't look like you any problems with low throws, is that as it was or did you get more throw out of it? the roll rate looked fine.
Aug 01, 2012, 03:47 AM
Fly Low!!!! No Sked.
AirHermit's Avatar
WOW! awesome Video Shawn. Thanks for the motivational Flying.
I crashed my Sbach Pretty hard today behing that barn in my vid. Stupid ar6200 Rx browned out on me while I was attempting an "Elevator". It Nose planted from a good 80-90 ft. One thing good is that my trims was spot on, for that sucker went litarally straight down.
Aug 01, 2012, 05:55 AM
Thanks Dan. Every thing is standard "out of the box" for the video. I will be adding longer aileron arms for more throw. Mainly personal preference, but as you can see its good with the standard set-up.
Don't feel to bad. I handed the radio to a friend and we did the same maneuver from about 50 foot. My fault. I put it in pretty hard just prior and did not check things out. Elevator let lose so my friend had no control.
On the bright side…..very little damage and what there was can be fixed very easly with welders and 5 minutes. Gotta love EPP.
Aug 01, 2012, 06:03 AM
Only 1800's on a 48"? Id expect at least a 2200. Have you tried 4S on this beast yet?
Aug 01, 2012, 08:43 AM
Team Twisted!
cdee's Avatar
Gravitycheat.... looks like it flies nice... about half way thru my build... hope to have it in the air by the end of the week-end.
cdee
Aug 01, 2012, 01:48 PM
1800 to keep it lite. I will be running 2200s. 4 s!!!!
It would be a beast on 4s. Can you say ovet kill.
[QUOTE=cdee;22324770]Gravitycheat.... looks like it flies nice... about half way thru my build... hope to have it in the air by the end of the week-end.
cdee
Look forward to hearing your opinion cdee
Discussion Twisted Hobbys - RC Factory USA Sbach 342 39" Build Thread & Flight Video!!!!! aerofundan 3D Foamies 497 May 24, 2015 08:01 AM
Discussion Twisted Hobbys - RC Factory USA YAK-55 39" Build Thread/Videos & Flight Video!!!!! cbriggs11 3D Foamies 78 May 28, 2014 05:40 PM
Discussion NEW Twisted Hobbys/ParkAero RC Factory 31" Sbach 342 Greengiant 3D Foamies 130 Jan 24, 2013 02:49 PM
Discussion NEW RC Factory-Park Aero/Twisted Hobbys 31" Sbach 342 Greengiant 3D Flying 0 Nov 04, 2011 11:34 AM
Discussion RC Factory USA - Twisted Hobbys - 1.2m SU 29 Build Thread. hercdriver7777 3D Foamies 97 Oct 19, 2011 06:34 AM
