Jun 17, 2012, 08:26 PM
Tamjets's Avatar
Originally Posted by AirX
Tam,
What thrust you getting installed in the F100?
Eric B.
I didn't check. But it spin 44,500 rpm inflight data around 2.2kw.
Jun 17, 2012, 08:28 PM
Tamjets's Avatar
Originally Posted by Knife Liddle
Looks like old 90mm airframes are the new 70mm airframes, and the old 120`s are the new 90`s. Got to love it.
That means that the Old Turbines are the new 120`s.
With today batteries can handle higher amps.
Everything bump up the next level and save some weight with smaller fan package.
Jun 17, 2012, 08:36 PM
The best in EDF since 2005
Extreme_RC's Avatar
CS10 Rotors and parts are back in stock, plenty of housings too so bare fan units are available, and with the new Extreme Spinner that fits straight to the stock rotor without the extra machining process needed the price has come down!
Latest blog entry: Extreme RC AUSTRALIA
Jun 17, 2012, 08:42 PM
Tamjets's Avatar
That`s right, STUPID fast, stupid powerful, probably just plain stupid too, but we`ll see how it holds up.
It`s powered by a Turnigy 3126 that has been rewound to 2.5 turns for aprox 2900kv (need to measure it). I added a 4" long shaft and an extra front bearing to support the longer shaft. The motor has an OD of about 37mm so it`s in the standoff position. I`m using a collet style adapter, but I`ll have to check to see which one it is. No mods to the shroud except what was needed to fit the standoff block. The rotor is bare bones stock.
Note: This is competely insane to run this $15 fan like this. Don`t do it, don`t even think about doing it. (That way I can be the only guy who has one).
Just the Facts.............
6s, 22v ( ran a 6s2p10ah battery to hold voltage)
145a......sustained
3.2 kw....""
97oz thrust.....6lbs 1oz
261 mph efflux speed (measured with Eagletree V3)
Esc used is a Suppo 7s 200a (the type with adjustable timming (30 degrees) and pwm 16k)
I`ll post some pics later. I may have found the powerplant for my Squal.
Cost about $80 for motor/wire/fan/esc. Then add lipos.
You are nuts....
Today I blew up another rotor goes over 46k.
So two already blew up over 46k.
It been working flawless 44.5k rpm. Wish CS had better mix on the material adding 2-3% of fiber.
Than we can push harder.
Jun 17, 2012, 08:43 PM
Lee Liddle
Knife Liddle's Avatar
That F-100 was like a rocket. Looked great!
Jun 17, 2012, 08:54 PM
Tamjets's Avatar
Thanks Lee....
This F-100 two year ago I was fly with 90mm at 2.4kw and it was 8.5 lbs.
The speed is much slower do to poor sharp intake lip.
With the 70mm not worry much about the FSA and even sharp intake lip will not penalty as much with over 120 FSA.
Here I shed off almost a pound in weight and smaller fan easy to feed air to the rotor.
We had awesome effecient set up.
Jun 17, 2012, 10:03 PM
SKYRYDER1000's Avatar
yes...we do for $25 service charge.
Send to my shop and we can balance it.
Thanks for the reply. I'll be sending you one or two rotors sometime this week.
Jun 17, 2012, 10:08 PM
Tamjets's Avatar
Ok... I be look out for it.
Jun 17, 2012, 10:39 PM
erh7771's Avatar
A Skymaster T-45 empty weight with gear is around 13.5lbs
I have to get some lighter wheels
Jun 17, 2012, 10:43 PM
Tamjets's Avatar
Carf's Hawk is even lighter and bigger too.
Jun 17, 2012, 11:01 PM
erh7771's Avatar
Yeah, SM didn't keep the wings light...stabs feel like they've been balsa sheeted over glass and then glassed again..
I was planning on coming in somewhere around 17-18lbs and use a single fan
The ESM wheels I have are pretty nice they're just heavy when every ounce counts
Jun 17, 2012, 11:09 PM
Tamjets's Avatar
That with batteries?
You be looking at 21 plus
Jun 17, 2012, 11:11 PM
Tamjets's Avatar
Did you see the Carf hawk I convert while back?
Jun 17, 2012, 11:13 PM
Lee Liddle
This little fan has me taking a fresh look at all of the 90mm kits out there. Take the Golden Hawk F-86(Pro Design. I think ) It's too small for a 90mm. No room for lipos. Fish mouth intake. It would be perfect for this fan, plenty of room for lipos with smaller ducting and the intake could be reduced to a scale size.
Jun 17, 2012, 11:20 PM
Tamjets's Avatar
That my idea...LOL
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7700 Aug 29, 2020 05:43 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
