This thread is privately moderated by IBCrazy, who may elect to delete unwanted replies.
Feb 19, 2011, 11:11 AM
Engineer for Christ
IBCrazy's Avatar
The radio system is only available in 2.4GHz which means you need a different frequency for video which is why I recommended 1.3GHz. 900MHz works well too.
-Alex
Feb 19, 2011, 12:28 PM
Wannabe Engineer
tbear2195's Avatar
So you're suggesting I look into the 2.4 ghz for the radio control and what about these 2 products for the video?
http://www.rangevideo.com/index.php?...roducts_id=228
http://www.rangevideo.com/index.php?...roducts_id=222
With these 2 products and this one:
http://www.rangevideo.com/index.php?...roducts_id=226
Does everything else I need to do to get my desired range involve the antennas then? And if so, will I need an antenna tracker?
Feb 19, 2011, 01:10 PM
Engineer for Christ
IBCrazy's Avatar
Must you insist on Range Video? How about this any other 1.3GHz system. I personally use the 800mW from Urban Drones, RMRC, HobbyWireless, ect (they're all the same).
IBCrazy's FPV "New system" - Cloverleaf demo (4 min 42 sec)
-Alex
Feb 19, 2011, 01:25 PM
Wannabe Engineer
tbear2195's Avatar
Ha no I'm not insisting on anything right now because I'm not familiar with any of these sites. With the link to that product, you're saying I will be able to get the range I want with the proper antennas? Would these antennas be built or bought and either way, about how much are they going to cost?
What about the control range? Would you still recommend the 2.4 ghz booster from rangevideo?
Feb 19, 2011, 03:10 PM
bucket of prop wash
garrcass's Avatar
IB CRAZY that system is switchable from 900 to 1.3 ? whats the output mW
Feb 19, 2011, 04:04 PM
Guys does anyone know of a good cheap source for 0,9 or 1,3 Ghz video tx+rx combo in EUROPE? About 500mW
Feb 19, 2011, 06:57 PM
reznikvova's Avatar
Originally Posted by tbear2195
I'm looking at some products right now on rangevideo.com. Am I going in the right direction here?
http://www.rangevideo.com/index.php?...&products_id=5
http://www.rangevideo.com/index.php?...products_id=12
(Obviously I know not to use the same frequency for video and control, but that's not what I'm concerned about right now because each of these products are available in different frequencies.)
Hi,
Get these:
Video tx 1.3GHz 800mW with harness and antenna
http://www.rangevideo.com/index.php?...roducts_id=229
Video Rx with antenna
http://www.rangevideo.com/index.php?...roducts_id=232
KX171 G2 camera
http://www.rangevideo.com/index.php?...roducts_id=207
Camera wire set
http://www.rangevideo.com/index.php?...roducts_id=236
RVmic
http://www.rangevideo.com/index.php?...roducts_id=163
That's a complete audio/ video set.
And for R/C control I recommend FrSky system:
http://www.rangevideo.com/index.php?...index&cPath=62
Feb 19, 2011, 07:36 PM
Wannabe Engineer
tbear2195's Avatar
Hey reznikvova,
I really appreciate the advice but I'm on a pretty tight budget. I am pretty new to this so I just want some decent quality stuff to get started with and I might consider upgrading later.
I was looking at the FrSky system anyways, but I think I found a cheaper transmitter/receiver combo that I am more interested in.
What I am most worried about right now is just finding a set of products that can get me 3-4 miles of range with decent quality. It doesn't have to be professional or anything, just enough to get me started.
Feb 19, 2011, 08:01 PM
reznikvova's Avatar
Hi,
What is your budget?
Best,
Vova
Feb 19, 2011, 08:38 PM
Wannabe Engineer
tbear2195's Avatar
As of now, I don't have a plane yet. My goal is to get a decent sized plane (less than $200) with at least a 15 minute flight time. I want to be able to fly at a range of 3-4 miles. In order to do that, I was thinking maybe $100-$150 to get the camera, transmitter, and receiver, as well as the booster for the controller. But I don't want to start buying anything until I know how much the whole package will cost.
Feb 20, 2011, 03:32 AM
interesting combo
Originally Posted by reznikvova
Feb 20, 2011, 07:59 AM
Engineer for Christ
IBCrazy's Avatar
Vova - You need to change the geometry of that Vee antenna. The short parallel run at the feedpoint acts as an impedance transformer and will increase the impedance of the Vee and distort the signal. You need to move the feedpoint forward so there is no parallel run in the line. Model it in 4NEC2 (free software) and you'll see what I mean.
-Alex
Feb 20, 2011, 09:02 AM
Wannabe Engineer
tbear2195's Avatar
IBCrazy - I am considering this plane.
http://www.hobby-lobby.com/piper_j_5...34189_prd1.htm
Will that FrSky system work with this or can it be modified for this plane?
Also, if I get that transmitter/receiver combo that you suggested, where do I get that helical antenna and will this setup give me my 3-4 mile range?
Feb 20, 2011, 09:12 AM
Just trying to get a nut.
scrtsqrl's Avatar
Get an Easystar. It has a more efficient airframe and with proper incremental upgrades, will serve you from the the learning stages all the way out to 3-4 miles...Check my blog for some ideas.
Start small. Be patient. You will eventually get there. You will spend way more than what you have specified...but more importantly, you will have to LEARN quite a bit before you could safely venture out of the confines of your flying field.
Feb 20, 2011, 10:27 AM
Engineer for Christ
IBCrazy's Avatar
That plane should do fine, Although I don't believe the FRSky system will fit right in. There will be some hacking involved to do that. I do agree the the Easy Star might be a better first platform, though.
As for the Helical and Cloverleaf antennas you currently have 4 options:
1. Build them yourself per the following tutorials:
Helical antenna tutorial
Clverleaf antenna tutorial
2. Buy them pre built from me (or as kits). I have not officially launched the system yet, but have been sending out special orders.
3. Order them from Ready made RC. I just sent my first batch to them Friday, so they should have them in stock soon.
4. Have a fellow HAM build them for you or assist you. Most HAMs are quite helpful with beginning amateurs and often have experience with antenna construction.
-Alex
Discussion Can this cam be used for FPV ? SpookiePower FPV Talk 11 Aug 16, 2016 11:08 PM
Discussion How to calculate flight time - guide ikorman Multirotor Drone Talk 16 Jun 26, 2016 07:34 AM
Cool How cool would this be for FPV Kai_Shiden FPV Talk 4 Feb 18, 2016 09:02 PM
Discussion How many FPV pilots in the world? rbmaze FPV Talk 10 Aug 03, 2011 06:16 AM
Poll Would you be interested in buying Ready to Fly FPV airplanes from a new FPV store? FPVNOW FPV Aircraft 36 Oct 06, 2010 08:56 PM
