Video
Byron F-16 / Dynamax conversion.
Here is the video of Paul's Byron F-16 with dynamax conversion. Scorpion 4035-630kv motor. 12s 5000 pack. castle 110 controller.
Unfortunately, most of the video is 3/4 throttle or less because there was some flutter on a higher speed pass....but it still flies better than any Byron F-16 that i have seen. Flutter issue is currently being worked on by Paul. This flight was 5:08 ... from takeoff to touchdown. Enjoy....... |
Latest blog entry: Coming RCGroups review ... FMS Sabre
Wow, that sounded like a turbine. Way cool! I have an F-16 that also flutters at higher speed (anything above 3/4 thr). I haven't tackled that one yet, but imagine the only real solution is adding another carbon spar in the wings?
Great job! Diego |
What is with every time an electric airplane gets in the air, there is always some knuckhead warming up his engine powered airplane...and for what reason? Simply irritating....
EDIT: By the way, that is a very impressive jet and nice flying too! |
Air sally ,yes they are, looks like they are not center to each other,the right one has more up deflection then the left. just use the same transmitter setting that where programed when the plane was flying as glow,never had any problems but after the flight you could clearly see the difference in the two.I have a upgraded stab control servo on each side,so I will ajust then fly again. my thoughts would be the right one is trying to turn the plane. will look everything over very well.
Regards Mal |
Thread Tools | |
Similar Threads | |||||
For Sale | Byron F-16 kit, EDF conversion | bruff | Aircraft - Electric - Jets (FS/W) | 3 | Apr 05, 2007 08:38 AM |
Discussion | Byron F-16 E-conversion | esb-help | Glow to Electric Conversions | 6 | Feb 26, 2007 02:19 PM |
Byron F-16 Fuel Tank/Manifold Help needed | CTulanko | Fuel Jet Talk | 0 | Jul 16, 2004 09:37 PM | |
Discussion | Selling my Byron F-16 on Ebay | bullseye45 | Aircraft - Fuel - Airplanes (FS/W) | 2 | Mar 13, 2004 10:35 AM |
kyosho F-16/brushless conversion | jeddofrog | Electric Ducted Fan Jet Talk | 3 | Nov 12, 2002 09:48 AM |
