This thread is privately moderated by Turbosun, who may elect to delete unwanted replies.
Mar 13, 2003, 10:48 AM
Trader Rating: 0
Duratrax Intellipeak Deluxe Pulse Charger With Ac Power Supply
DURATRAX INTELLIPEAK DELUXE PULSE CHARGER WITH AC POWER SUPPLY
The power to peak charge, discharge, and Cycle NiCd AND NiMH packs
I am rationalizing my charger fleet. :-))) Unused so it's gotta go....Bargoon at $65 +SH!
This charger does it all. Can be used in the field as a DC charger, as well at home on AC. Includes the switching power supply. This allows you to use this Intellipeak charger for AC as well as DC. However, the bonus is that this switching power supply lets you use all your other DC-only chargers with AC power!!!
Note the discharge rates of either 2 A or 10 A....Highest in the industry short of the $400+ units.
This high 10 A discharge rate will train your cell in cycling mode for high loads!!!
DTXP4120Features "Negative Delta V" peak detection for NiCds and "Zero Delta V" peak detection for NiMHs
0.5A-6.5A fast charging for NiCds AND NiMHs
Automatically selects detection method
Detachable AC power supply w/built-in fan
2A or 10A discharging
Twin built-in cooling fans
They're more than simple sport chargers, and more than microprocessor-controlled peak chargers, as well: IntelliPeak Pulse Chargers are nothing less than combined peak charging, discharging and cycling units for NiCd and NiMH packs.
Cutting-edge engineering makes it possible to use their versatility with either AC or DC power. Use of solid-state components not only results in amazingly light, compact units, but levels of precision, reliability and price that any R/Cer can afford.
Standard features found on all IntelliPeak chargers:
Peak charging for NiCd & NiMH packs
Discharging at independent rates*
Pulsed fast charge current
Single and non-stop cycling modes*
Fully adjustable fast charge current*
AC/DC convenience
1-year warranty
Automatic trickle charge
High-intensity setup LEDs & sound cues
Overload and reverse polarity protection
Standard charge lead
For 4 - 8 cell batteries
Get 12V DC from any 110V outlet -- great for crowded workbenches.
It's incredibly small and light (just 3.9" x 2.75" x 2.5" and 7.2 oz.), yet delivers an amazing 7A of 12V DC power wherever there's a wall outlet or power strip. Solid-state components make it light and compact -- and its state-of-the-art, high-frequency (22KHz) switching design not only eliminates huge, heavy transformers, but leaves room for a built-in fan to promote cooler operation and higher reliability.
A fistful of power that weighs only 7.2 oz.!
FEATURES: Peak charges nickel-cadmium and nickel-metal hydride batteries using two specialized peak charging technology for nickel-metal hydride batteries, plus discharging and cycling features not commonly found in other chargers. "Negative Delta V" peak detection for NiCds, plus advanced "Zero Delta V" peak detection technology specifically for NiMHs, providing full charges without overcharging. Built-in Artificial Intelligence to eliminate false peaks. Auto-selects peak detection method by identifying cell chemistry. Auto-identifies the quantity of cells being charged. Computerized control, 8-bit 4MHz CPU with 8K ROM, 1K RAM, 1-channel 16-bit analog-to-digital converter. High efficiency P-Channel MOSFET drive transistors. 11-15V DC input. Incredibly small, detachable, 12 volt 7 amp AC power supply with built-in cooling fan for at-home use. Output: 4-7 cells on DC, 4-8 cells on AC. Adjustable fast charge current of 0.5-6.5 amps. Pulsed fast charge, with 8-bit pulse width modulated current control output. 100mA trickle charge. 10 and 2 amp fixed discharge rates, selectable by switch. Fixed 2.60V discharge cutoff voltage. Cycle functions: Select a single discharge/charge cycle for periodic pack conditioning, or continuous "auto-repeat" cycles for reviving batteries that have developed a memory, or for breaking in a new pack. Four multi-function, high intensity LED indicators. Status light glows during charge and flashes when nearing peak. Audible mode select tone signals for easy set-up. Twin built-in miniature fans keep the charger cool, increasing efficiency and lifespan. Reverse polarity and overload protection.
REQUIRES: DC power source of 11-15 Volt, OR AC power source of 110 Volt (United States Standard AC)
SPECS: Battery Types: Nickel-Cadmium (NiCd) Nickel-Metal Hydride (NiMH) Charger Type: Pulsed Current, Peak Detecting Peak Detection Method: Negative Delta V and Zero Deta V AC Input Voltage: 110 (United States Standard AC) DC Input Voltage: 11-15V DC Number of Cells: 4-7 cells DC or 4-8 cells with AC power supply NiCd Fast Charge: 0.5-6.5A NiMH Fast Charge: 0.5-6.5A Trickle Charge Rate: 100mA Discharge Rate: 2 or 10 amps selectable Discharges down to a fixed voltage of 2.60 volts. Width: 5.4" Height: 2.25" Depth: 4.0" Weight- Charger: 14.1 oz (without power supply) Weight- Power Supply: 7.2 oz
Mar 13, 2003, 11:02 PM
Trader Rating: 0
Pricedrop: $60 + SH.
BTW, listprice is $139.99:
http://www.hobbyhobby.com/cars/produ...pulse_info.htm
Mar 14, 2003, 08:47 AM
Trader Rating: 0
ttt
Mar 14, 2003, 10:43 AM
Trader Rating: 0
excuses, the quoted list of $139.99 price is in Canadian $
FYI: 1US$=0.6733 CAN$
I knew the price went up last year...but not that much...
Mar 15, 2003, 12:58 PM
Trader Rating: 0
the deluxe is sold, the other mini Intellipeak chargers (see my other listing) still available...
Duratrax Intellipeak Deluxe Pulse Charger With Ac Power Supply Turbosun Aircraft - Electric - Airplanes (FS/W) 9 Mar 16, 2003 03:08 PM
