Jan 28, 2009, 02:40 AM
DX6i - Make the flaps and gear switches act like 3 position switches
Orignaly posted in another thread but figured it sould get it's own thread since it could be usefull to anyone with a DX6i (not sure the DX6 is the same config as the DX6i).
Although Not exactly like I thought the first time, go figure.
Here is the configuration and what the results of the switch positions are.
Gear 1 / Elevator DR 1 = Center
Gear 0 / Elevator DR 1 = Left rotation 45%
Gear 0 / Elevator DR 0 = Left rotation 45%
Gear 1 / Elevator DR 0 = Right Rotation 45%
Also works mixing Flaps with Ail D/R, just make sure to go in and set the flaps to actually do something. On my DX6i servo travel was defaulted to 0.
Feb 02, 2009, 06:44 PM
How do I change this text?
Darth_Elevator's Avatar
Thanks, I'll give this a try.
Feb 02, 2009, 09:27 PM
charlie eaton's Avatar
Have you seen the service bulletin on the DX6I? With some units there is a problem with the stick pots. The problem can be found in units with the date codes of HE809E,HE810E,HE811E and HE812E. On the servo monitor display if you find a hesitation instead of a smooth tracking movement you need to sent it back for service.
Discussion Setting up the DX6i with 3 position flaps? simon737 Radios 3 Nov 07, 2009 05:31 PM
Futaba 9C 3-Position Switches mpoole Radios 0 Sep 19, 2005 10:31 AM
FS: Graupner Speed Gear 480, 7.2V, 3.45:1 PDX Slope Pilot Aircraft - Electric - Airplanes (FS/W) 2 Oct 19, 2002 10:14 AM
I want to make/mould some landing gear. Kevin Cox Modeling Science 0 Aug 06, 2002 05:41 PM
Landing gear for EAM S-3 Viking? Reco Electric Ducted Fan Jet Talk 1 Apr 01, 2002 08:53 AM
