Jan 25, 2009, 01:07 AM
Video
Vanilla Delta Pusher Jet Loop 'n Roll
Just a basic but good-looking delta, flying basic acro. It's almost entirely 10mm Cellfoam 88 and weighs about 10 ounces, but the ELE outrunner gives it well over 10 ounces of thrust. I've got it turning a huge APC 7X4, and the effect of it is that the model's speed is controlled almost directly by the prop RPM. Throttle up and the model accelerates to match the prop no matter what direction it's pointing. Throttle down and it won't speed up even when it's pointing straight down. This model flies the opposite of a jet, there's no feeling of momentum being conserved, no zoom climbs or maneuvering to bleed off speed before a descent, but it does have basically infinite power and acceleration. Here it is over Pole Green Park (a few miles north of Richmond International Raceway), fighting through a brisk day to pull off the most basic aerobatics in its catalog (640X480 below):
Delta Foamie Pusher Jet (1 min 20 sec)
Feb 24, 2009, 05:38 AM
Plans are up!
https://www.rcgroups.com/forums/show....php?t=1006728
RE
New Product Delta 3/C 10mm pusher Jet TaSaJaRa Pusher Prop Jet Models 31 Mar 26, 2009 06:07 AM
Discussion Delta 3/C 10mm pusher Jet TaSaJaRa Foamies (Kits) 6 Feb 18, 2009 04:38 PM
Discussion Delta 3/C Pusher Jet hapyjac2 Foamies (Kits) 1 Dec 02, 2008 10:25 AM
Discussion BP-12 Delta use in a pusher jet spacemanspiff Pusher Prop Jet Models 5 Apr 01, 2006 04:08 PM
Delta pusher jet build intermision Electric Ducted Fan Jet Talk 0 Nov 16, 2004 08:45 PM
