Sep 19, 2016, 04:03 AM
NewFlyer
KenChin's Avatar
Kinda miss my Night Flying.. Still have 2 Bare Air-Frame - Dusty in Store.
Mar 05, 2017, 02:25 AM
RC Mad
Ken,
I sent you a PM...
Regards
Aug 06, 2017, 11:41 PM
NewFlyer
KenChin's Avatar
Yes... I am back in here! A good first step before charging up..
Sep 29, 2017, 07:16 AM
davereap's Avatar
Hi..... I have resurrected a micro kite.. I built it a while back, then did many other models...
Now flown indoors the performance is excellent.. rolls loops hovers etc its a crazy model..
I first of all I had the thrust lines set at zero.. this gives some extra wild speeds and less stability.. crazy flying here..
And every so often it would go into hyperdrive .. accelerating to a way too fast speed.. likely a result of its extremely thin profile
So I added downthrust, about 5 degrees and compensated with some up-trim..
This gave a much steadier cruising flight .. still fully aerobatic.. and crazy enough for me..
At slow speed its floating about, hovering is easy and stable, rolls fast, loops tight and axial, inverted easy stable....
specs 1811-2900, 2s 500 lipo, 6x3 prop, 6A ESC, auw 4.5oz for a 3.2ozsqft loading.. enough power for vertical hover etc...
Its so good that I am now going to go with an EPP version for our indoor bash and crash..
Sep 29, 2017, 03:02 PM
I like your design Dave!
If you put a thrust vectoring motor on it ... you will be in heaven! How do I know? the Big Daddy here:
https://www.rcgroups.com/forums/show...postcount=1116
Is still flying strong and is the hit of airshows for kids today.
Your design is right on the money for a great flyer! Congrats!
Oct 02, 2017, 03:42 AM
davereap's Avatar
And I like your big kite..
My Micro crazy kite needs some tiny LEDs
And now the EPP version is built.. I used 8mm EPP..
specs 1811-2900, 2s 500 lipo, 6x3 prop, 6A ESC, auw 5oz for a 3.4ozsqft loading.. 1.47sqft.. again enough power for vertical hover etc
flown.....
The COG was too far back, and flight was tail down and poor.. to get a better COG Ive now got a 2211-1700 with an 8x4 prop and Ive also fitted a CF bumper.. weight now at 5.7oz for a loading of 3.87ozsqft..its possibly still a bit too far back... flying it will tell..
Oct 07, 2017, 07:10 AM
davereap's Avatar
here is a video with the micro kite.. this is an excellent model, it floats along lovely..
micro kite 12 10 17 (7 min 25 sec)
note the video is on the kite version not the crazy as seen on the intro picture
micro crazy 12 10 17 (9 min 22 sec)
Oct 15, 2017, 04:05 PM
davereap's Avatar
And the Crazy is now improved with a correct COG, bumper bar, larger motor.. its excellent
micro crazy 1 12 10 17 (4 min 26 sec)
Nov 17, 2017, 02:31 AM
davereap's Avatar
more indoor flights of the "crazy"
simple build crazy indoor flight 16nov2017 (4 min 31 sec)
simple build crazy indoor flight2 16nov2017 (5 min 18 sec)
Aug 27, 2018, 01:56 AM
NewFlyer
KenChin's Avatar
Here's my favorite acrobatic kite. Completed, Maidened and Found the sweet Down-Thurst + CG for a comfortable flight.
Kinda stuck in between if i should turn this into a Night Kite or not..
Sep 24, 2018, 01:39 AM
davereap's Avatar
did you find any info on these designs... the changi airport butterflies...
Sep 28, 2018, 01:53 AM
NewFlyer
KenChin's Avatar
Not really. But i do know they have a separate controller on board for flapping the wings. Likely it's also programmable with different modes.
Build one? I have other priorities currently for "Wau Bulan". Malaysian traditional kite to RC conversion.
Nov 20, 2018, 10:04 PM
NewFlyer
KenChin's Avatar
I've just installed Fairy Lights onto my Kite. They are 3V LED, available in one color or mixed. I tap them directly onto the Balance Port of the Lipo.
Discussion RC Kites New Domain airdancers Parkflyers 2 May 17, 2016 04:02 PM
Alert Ripoff RC Kites by this company!! rckiteflyer China 8 Jan 04, 2016 03:31 AM
Careful! RC Kites (the Fakes) on eBay??!!! ManGotea Parkflyers 4 Oct 01, 2007 08:08 AM
Question night fliers blueman Foamies (Kits) 16 Apr 17, 2004 01:42 AM
Question for night fliers flipnidaho Parkflyers 2 Jan 04, 2003 10:21 PM
