Scratch builder paint tips / ideas: instructional videos - Page 134 - RC Groups
This thread is privately moderated by adreher, who may elect to delete unwanted replies.
Jul 02, 2017, 11:21 AM
sparrow1's Avatar
Thanks. the specific rustolium were using says it can be thinned with water, which is nice so ill experiment with mixtures and share results.
Aug 15, 2017, 10:12 AM
In the past I have painted everything the same way with different kinds of foam with good results.I sand,then hide imperfections with light weight spackle,sand again until smooth,then paint with a latex house paint.I recently watched a video where a guy put a couple coats of water based polyurethane on some Lowes styrofoam,(the blue board)for a nice hard coat of protection.He applied it directly to the foam and wasnt going to paint it,just wanted the protection.Heres my question.I am building a plane with a stock pre made fuselage made of z foam and my scratch built wing I made with the blue styrofoam from lowes and I want to use the polyurethane but Im not sure what to put on first.Is it best to do the spackle first,then paint and coat it with polyurethane last or start with one of the others,or does it made any difference.I would like to use an oil base for a much glossier shine but not sure if that is good idea or not.Advise is needed and appreciated because I have spent alot of time on this wing and ailerons and dont want to ruin them
Aug 15, 2017, 11:59 AM
Cobra Driver
RedTwilight's Avatar
I would do the spackle first to get the surface a smooth and dimple free. After that is sanded smooth wipe it with a tack rag to pick up any dust or lint. Then go with a coat or two of water based polycrylic. Then apply your paint followed by another coat or two of poly.
I wouldn't use the oil based. It will most likely have unfavorable reactions with the paint and will "yellow" over time.
Aug 15, 2017, 12:12 PM
That was what I had in mind from the beginning but I didn't want to take a chance or use up alot of time and material on some scrap pieces.I thank you for your quick reply and if you have done this on your models before I will go out and pick up the water based polyurethane today.Since I have nearly a gallon of the oil based was why I asked about that.If you haven't actually done it on a model and its an educated guess I will wait for a few more replies from others because I 'm waiting for my battery and couple more things to arrive in a couple days and I have that time to keep me from hurrying into it like I do sometimes and pay the price .Thx again for the quick response
Aug 15, 2017, 02:29 PM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Yes RedT is very correct, I have had success with his method. Sparkle/ light filler, sand and wipe clean, oil free. Seal with waterbased clear. Paint and seal again to make that paint really "pop"!!
Aug 16, 2017, 12:19 PM
gittarpikk's Avatar
Also you can use the masking paper and white glue method to cover for a really smooth and level painting surface ...its on youtube.
Just dont use the water based for a nitro plane as it is not fuelproof...ask me how I know
Nov 19, 2017, 10:02 AM
Does anyone know where to by something similar to Liquid Sheeting?
Wowplanes has closed there shop.
I red somewhere about Styrospray 1000 but it seems impossible to get something similar here in europe?
I will have a gowith 2K waterbased floor varnish.
What do you Think about that? The plane is rather big, built of white foam.
// Mats W
Nov 25, 2017, 06:40 PM
// Mats W
interested in this too.
working with FT design models but not using foom that has paper backing im still trying to figure out an easy method. packing tape works but only looks good for flying wings where you can 2 tone the colour scheme.
wondering if something like this could act like the paper, or if use masking tape to get everything togethr, remove the masking tape and then coat it with this aftger painting to toughen it up and maintain the strength afte removing paper
Nov 28, 2017, 06:49 AM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
One “might" think Foamies with a total paper or any backing would be unnecessary. On "bare foam" planes we just cover the LE and any high wear areas with a little bit of paper masking tape … But alas this is only good for backyard Foamies and not 100 mph speed record attempts … Back ten years ago , we’d peel the plastic films off Blucor FFF in order to get the lightest weights ..
Latest blog entry: Lost plans
Dec 14, 2017, 02:34 PM
flyin' fool
goldguy's Avatar
Painted with an artist sponge and acrylic .......................
Dec 15, 2017, 05:47 AM
Squall's Avatar
Looks great!
Feb 03, 2018, 07:29 PM
Build, crash...repeat
AleRRon's Avatar
Edge 540
I built an EPP Edge from Leadfeathers plans and painted it with an airbrush using Adrehers instructional videos. I love his techniques. You can paint anything imaginable! I learned a lot from him and from this project. Thanks Adreher and Leadfeather. I’m afraid to fly it now! I built another similar aerobatic EPP plane and all I managed to do was crash it and repair it.
Feb 04, 2018, 07:00 AM
Squall's Avatar
Wow! Good job! Don't be afraid to fly it
Feb 10, 2018, 10:09 PM
GeoStork's Avatar
Could you post a link to those instructional videos? What type/brand airbrush do you use? Stunning paint job!!
Feb 11, 2018, 08:46 AM
gittarpikk's Avatar
Has anyone came up with a bullet proof method of priming laminate before painting with something like acrylate or rustoleum 2x (melds to plastic)
I have tried priming with plastic melding primer (rattlecans) and just shooting straight rattlecan rustoleum 2x directly over laminate , but when masking , even masking tape that has had the adhesive weakened considerably will still peal the paint off the laminate.
The laminate is really slick and the only thing that seems to stick to it is spray 77 or laminate itself when heated . Not sure if the 77 would peel up is a precoat is sprayed first before painting or would affect the paint layer such as orange pealing etc.
My next foam project is going to be a remake of the 10' Woodys Pusher I did with DT foam board and Tape Brothers tape. Fuse was done in laminate with primer and Rustoleum 2x ...but had the bad peeling problem.
This time I may just use hot wire cut EP with the paper painting mask/white glue covering method and then laminate it.and follow with acrylic..but need to get the paint to stick really well. So whatever method I need to prime will be crucial to making the acrylate stick.
Fuse will be block frame of peeled DT foamboard with balsa corners and frame glued exterior on the frame, then laminated open frame style and painted with Acrylic.
Scratch builder's miniture miter at harbour freight splatman Scale Kit/Scratch Built 1 Dec 01, 2016 07:29 AM
Tips for Taking Videos? kelvin Electric Plane Talk 48 Apr 18, 2003 01:55 PM
Gimme some paint scheme ideas for the Pico Jet Pierre Audette Foamies (Kits) 7 May 23, 2002 08:32 AM
New Zagi 400x builder, any tips for me? slowflyer Foamies (Kits) 16 May 09, 2001 04:28 PM
