Jan 16, 2009, 01:18 PM
Site Aspie
Lynxman's Avatar
Build Log
The World Models 1/3 Super Cub.
This thing is ridiculous. It's not exactly scale perfection, but it's a fun sports scale model (I hope).
I'm going to power it with a cheap hobbycity Turnigy-motor on 12S 5000, 6000 or 11000 mAh, whatever it needs to balance.
More info later as I put it together. Oh, and my friend bough a 1/3 J-3 from TWM as well.
Latest blog entry: EL-39 compilation video
Jan 16, 2009, 10:50 PM
AmpAce's Avatar
Interesting project, I will be watching!
AmpAce
Jan 17, 2009, 09:52 AM
Site Aspie
Lynxman's Avatar
I don't plan to make a lot of mods for it. I'll make the vertical stab assembly removeable to make transportation easier. Maybe I'll recover it in sloartex some time. If I do I'll modify The wingtips to make them more scale as well. Now they are flat on the top. I think I'll change the shape of the wing leading edge where it goes through the fuselage to make it look more scale. I have ordered some Dubro 1/3 Cub wheels for it. The stock wheels look skinny and strange.
The construction is incredibly strong and is made from a lot of plywood. I would have used more balsa myself if I wasn't too lazy to build these days, but it's not going to be too heavy. From what I've seen on youtube it's a light flyer. The servos are supposed to be mounted in the tail. I might mount them all farther forward, in the cabin if possible with pull-pull wires, at least the rudder servo.
Putting it together can be done in a couple of nights if it's kept stock, it really is that easy to assemble. All the hinges are installed from the factory and if the manual is accurate they are also pinned.
I have ordered Hyperion Atlas DS20FMD for everything but the rudder and DS20UMD for the rudder. Should be more than adequate with sensible servo arm geometry.
Jan 17, 2009, 10:10 AM
In NY's beautifull hills
staggerwing's Avatar
What is weight as pictured & an estimation RTF ?
Thks
Bob
Jan 17, 2009, 11:16 AM
Site Aspie
Lynxman's Avatar
I haven't weighed it yet, but I will weigh the empty kit weight and post the data here soon.
Jan 17, 2009, 01:17 PM
Site Aspie
Lynxman's Avatar
Fuselage with complete landing gear and wheels installed: 3300 g
Cowl: 169 g
Wing tubes and struts: 1284 g
Balsa/ply internal trays: 130 g
Untrimmed windows/windshield: 289 g
Various hardware in a big bag: 545 g
Pilot bust: 110 g
Vertical stab: 139 g
Horizontal stabs with steel joiner rods: 406 g
LH wing: 1335 g
RH wing: 1323 g
Total kit weight: 9030 g (19.91 lbs)
The complete tank weighs 216 g, for those who want to gas it up.
Jan 17, 2009, 01:29 PM
Site Aspie
Lynxman's Avatar
Hyperion DS20FMD/UMD servo weight: 53 g * 7 = 371 g
Futaba R608FS receiver: 14 g
Dimensionengineering VHVBECs: 17 g * 3 = 51 g
~9 m of servo cable: 180 g
Motor: 840 g
Motor mount: 150 g
ESC: 125 g
Prop: 90 g
Estimated weight without batteries: 10851 g (23.92 lbs)
5000 mAh 12S ZippyH lipos: 1590 g
Estimated 5000 mAh weight: 12444 g (27.43 lbs)
6000 mAh 12S Hyperion lipos: 1630 g
Estimated 6000 mAh weight: 12481 g (27.52 lbs)
11000 mAh combined: 3220 g
Estimated 11000 mAh weight: 14071 g (31.02 lbs)
This should be pretty close unless I forgot something. What did I forget?
EDIT:
I forgot the motor mount.
EDIT 2:
I added lbs in brackets.
Last edited by Lynxman; Jan 23, 2009 at 06:17 PM. Reason: I forgot the motor mount.
Jan 19, 2009, 10:43 AM
Plastic Buddha
aftica's Avatar
Jan 19, 2009, 04:18 PM
Site Aspie
Lynxman's Avatar
I'll head over to my friend and take some pics of the J-3 when he gets it. The J-3 is the old version with the fixed tail while mine is the new version with the removeable horizontal stabs. The old version has the kit number A186 for the J-3 and A186S for the Super. The new versions are called A186R and A186SR respectively.
Jan 22, 2009, 05:17 PM
Site Aspie
Lynxman's Avatar
I just finished milling out the parts for the motor mount. I'll finish it tomorrow. The side plates are 0.063" 2024-T3 and the thicker pieces are 6 mm 6082-T6 aluminium.
EDIT:
Oops. I made a mistake. I'll have to make new side plates. that's what happens when you come home from work tired and try to use your head.
Jan 22, 2009, 08:58 PM
Can't wait for the end result.
Jan 23, 2009, 12:10 PM
Site Aspie
Lynxman's Avatar
The J-3 arrived today along with the servos and wires. I have everything I need to finish it now except a 12S ESC, but I can prop it for 10S initially if I don't get a new ESC by the maiden.
As far as we can tell the only difference is the cowling, lack of flaps and longer ailerons on the J3. Since his is the old version the horizontal stabiliser is not removeable, while it is on my Super Cub. There is more room in the SUper cowling of course, both in length and width. The Super Cub has 207 mm of space from the cowling to firewall while the J3 has 190 mm.
Jan 23, 2009, 03:43 PM
Site Aspie
Lynxman's Avatar
Here's the almost finished motor mount. I milled two new side plates and drilled and tapped the bolt holes today. The only thing left is to bend the mounting flanges. I don't have a brake at home so I'll take it to work tomorrow and bend them there.
Jan 23, 2009, 03:57 PM
ONEHANDRC
gallfer's Avatar
I was just given a partially built 1/3 Cub and don't know what size motor to use. What's going in yours? Thanks! Now I need to get back to the B36 thread.
Jan 23, 2009, 04:06 PM
Site Aspie
Lynxman's Avatar
I'm going to use the one in the pictures. It's one of these: http://www.hobbycity.com/hobbycity/s..._170Kv_/_3250W
I don't know if the constants are accurate, but it should be possible to drive a 23" prop, which is the scale diameter, at 10S or 12S and 2000-3000 W. More than enough power. I have a feeling the plane will fly quite comfortably even with just 1500 W available.
For Sale World Models 1/3 Super Cub, NIB, $750.00 shipped by bus LOWER PRICE be69ar Aircraft - Fuel - Airplanes (FS/W) 0 Oct 24, 2008 10:44 AM
Discussion Balsa USA 1/3 Super Cub btomlinson Scale Fuel Planes 5 Aug 29, 2007 12:03 PM
Discussion World Models 1/3 scale Cub levelution Giant Scale Airplanes 25 Sep 20, 2006 05:28 PM
For Sale 30%ultimate Trade For 1/3 Super Cub flylow777 Aircraft - Fuel - Airplanes (FS/W) 0 Jan 25, 2006 11:16 PM
FA World Models J-3 Piper Cub w/Jeti 20 ESC ArkyTazman Aircraft - Electric - Airplanes (FS/W) 4 Mar 23, 2005 06:30 PM
