This thread is privately moderated by neven, who may elect to delete unwanted replies.
Jan 14, 2009, 10:36 PM
neven's Avatar
Idea
blade tracking quick and easy preflight check.
Hey everyone, I just thought I'd share a tracking tip for anyone that may be interested. I have read in many posts and also experienced myself the sometimes finicky blade tracking of the mx 400 line of helicopters, especially the mx 450. Some nights I would spend hours trying to get the blades to track by hovering it in my basement, only to find out next morning that the blades are out of track again. very frustrating.
I think I figured out a simple way to do a quick blade tracking flight check before the heli is in the air. It's worked for me so far.
1. connect the battery to the heli to make sure servos are in proper position.
After they align to their position, I disconnect the battery so the motor doesnt start suddenly while I do the following.
2. in the first picture, looking at the heli from top down, rotate the blades in their blade holders towards the side their leading edge goes, so it looks like the second picture(rotating them in this direction makes them pull on the linkages as they would in normal flight, making it easier to take a more accurate pitch measurement). make sure the blades are over the paddles.
3. then in the third pic, put the heli on a table on its skids and look at it from the side, compare the distance between the blade and paddle on both sides, I just eyeball it. Then, rotate head 180 degrees to check if gaps are the same still. if gaps are the same I fly the heli and blades track good. if gaps are off, I adjust linkages, and I am able to see the effect of those changes almost instantly, before I even connect the battery to the heli again.
hope someone found this helpful, it is by no means a replacement for a pitch gauge but it works for me for a quick pre flight check.
Jan 21, 2009, 08:29 AM
BeeZaur 480
BowerR64's Avatar
How do you set the paddles? What if they are a little off?
Feb 15, 2009, 02:04 PM
neven's Avatar
Hey Bower, I do need a pitch gauge for the paddles, and will get one, so far I've been eyeballing them, and it seems to be ok. Better to be sure tho.
Discussion Blade Tracking with CP2??? CHECK THIS OUT!! garylee33 Micro Helis 16 Dec 15, 2006 09:24 PM
Mini-HowTo BCX lower blade tracking, easy fix! Hauntme13 Coaxial Helicopters 1 Dec 03, 2006 09:35 AM
Hornet Blade Tracking RC Man Electric Heli Talk 7 Aug 21, 2002 11:40 PM
Piccolo Blade Tracking? / Vibration 3dben Electric Heli Talk 1 Aug 11, 2002 03:02 PM
Twinstar maiden flight-preflight check Ratbait Foamies (Kits) 3 Feb 16, 2002 09:43 PM
