Mar 04, 2003, 03:29 PM
Glue for plastic
I want to glue a few Derlin plastic parts together. What type of glue would you recomend?
Mar 05, 2003, 11:36 AM
You can't glue Delrin. I would first try to fasten the parts together with screws, etc. And if that is not possible, then sand the mating surfaces with coarse sandsandpaper and use 24 hr epoxy. (NOT 5 min epoxy, 24 hour epoxy)
Mar 05, 2003, 11:46 AM
What kind of plastics glue together good?
Mar 06, 2003, 06:28 PM
Without knowing what you're using the plastic for, it's hard to tell.
Most plastics have a specific solvent type glue that works for that type of plastic: ie ABS solvent for ABS plastic, styrene solvent for styrene, acrylic solvent for acrylic plastic.
Try this link:
http://www.ipscorp.com/
If you're machining plastic parts, I would suggest ABS plastic and use the corresponding weld-on cement for ABS.
Mar 07, 2003, 03:36 PM
Thanks for the link.
Mar 10, 2003, 03:30 PM
Oxford Panic
AndyOne's Avatar
Chris,
Try Supacrylic or Plastic Magic from Delux Materials, I assume they have an outlet in the US.
Their adhesives are expensive but they work and when epoxy won't.
http://www.justtrains.co.uk/Deluxmaterials.html
Andy.
Help! Best glue to attach plastic deck to the plastic hull??? Jcopter Scale Boats 20 Jul 10, 2018 10:10 AM
Discussion What glue works best on plastic frames jbt101 Mini Multirotor Drones 2 Nov 09, 2016 01:50 PM
Question Best glue/epoxy etc to stick Wrapped Carbon Fibre Tube and ABS plastic together? Blacken The Builders Workshop 6 Sep 02, 2016 05:38 AM
Discussion Glue for Plastic Parts - Circuit Boards Curado Kev Beginner Multirotor Drones 5 Jul 30, 2016 09:34 PM
Discussion Plastic glue Tony F Electric Plane Talk 10 Oct 14, 2015 06:16 AM
