Dec 24, 2008, 08:23 PM
Frame Design Engineer
superdave42's Avatar
Cool
Simple / Clean 4#3B Bell/Hiller mod
When I first got my 4#3A I instantly liked it. it flew very well for being so small. Then the never ending urge to MODIFY suddenly took over.
I wanted faster response.
I wanted more agility
I wanted it to look fast standing still.
I just wanted to be different..
I am not the first person to do this mod on a 4#3, EQMOD and some others have done this as well. I just wanted to make it all out of off the shelf Walkera parts.
So I extended the tail by .5" and installed the 4G3 tail assembly.
Installed some Tuff struts (which looked very funny until I modified them, gave it the rake angle).
Swash support.
Blue -Q grips
Bell/Hiller Mod:
This mod worked out very nicely, gave me exactly the level of response that I had imagined it would.
My first goal was to make it all work with off-the-shelf parts.
it basically consists of:
1. Mixer arm (from 4G3)
2. Mixer arm shoulder screw (from 4G3, needs to be cut in length)
3. Linkages (made from 2nd set of 4#3 dog bones cut 30% off, 4G#3 plastic ball link, the connecting tube is a cut stock ball link shank)
4. Flybar linkage ( stock 4#3)
it's very simple and instantly gratifying.
Pretty much has the cyclic response of the 4G3 now. only tested so far in my living room because it's storming outside.
I'm sure the geometry is not perfect, but it does have a totally different feel now.
Dave
Dec 24, 2008, 08:27 PM
Video please. In flight and mechanical movements.
Dec 25, 2008, 09:34 PM
EQMOD's Avatar
Great mod! Any flight video ?
For best results you need to keep those mixing arms on both side parallel with one another.
Dec 25, 2008, 10:02 PM
that's gonna leave a scar
KCinNC's Avatar
nice job man !!
Dec 25, 2008, 10:03 PM
Thanks eqmod.
I know ideally you want paralell and 90 degrees. But this is what you get using the stock flybar linkage and it works fine. I think this little heli has a few compromises out of the box. This I'm sure most will consider a compromise as well. Anyone with B grips can try this quite easilly.
I'll try to get a flight video. It really us night and day difference.
Dec 26, 2008, 05:47 PM
Some short video
4#3B bell-hiller mod 1 (0 min 44 sec)
4#3B bell-hiller mod 2 (0 min 12 sec)
4#3B bell-hiller control (0 min 16 sec)
Dec 30, 2008, 06:48 AM
flying beam
blackmoon's Avatar
Hi,
In your video, are you giving some quick and crisp cyclics to test it?
Because it seems rather unstable.
Thank you.
P.
Dec 30, 2008, 02:50 PM
Originally Posted by blackmoon
Hi,
Thank you.
P.
Yes in all the videos I am giving fast side to side and front to back stick movements, just to show that the cyclic is much faster now. that Hiller lag is definitely gone now.
Dec 30, 2008, 03:02 PM
flying beam
blackmoon's Avatar
Thank you.
Paulo.
Jan 03, 2009, 04:03 PM
Dave,
I have now made the exact same mod on my 4#3b, the difference in flying is amazing.
It's like night and day, shame I broke the pin that holds the tail rotor.... doh
Jan 03, 2009, 04:23 PM
Originally Posted by kermitthefrog
Dave,
Hi, glad it worked for you :-) I love it.
I have been pondering making different ratio arms now. looks like the ratio is 2:1 currently and I might try 1.5:1 and 1:1 and see if it gets even better.
if you still have your tail skid rod,, you can use that as a rotor shaft until you get a new one :-)
Dave
Jan 03, 2009, 04:57 PM
Dave
Thanks for the trick to fix my tail rotor.
Regarding the length of the rods in the BH mod, I guess they have to be the same length, is that right?
Jan 07, 2009, 05:52 PM
cool.
yes the rods need to be matched length.
Jan 07, 2009, 05:53 PM
Backasswards
I just realized that all of us that are using the 4G3 mixer arm to perform this mod have the bell/hiller ratio BACKWARDS lol I think it was because the parts just fit better this way. but in reallity what we really want is to have the the Flybar give more input than the swashplate.. like all the other normal B/H mechanics..
hehe yeah it works, but we may just find the flight more enjoyable with the correct ratio allocation.
anyways, not sure if anyone thought about this, I sure did not.
with the correct ratio the flybar will work better and then still allow the direct swash input to help get things going.
hehe.
Dave
Jan 07, 2009, 06:11 PM
Air Vaca's Avatar
looks like you have the flybar with more authority. The swash to mixer has to move further to have affect. A fixed length will cover more degrees of a smaller circle.
Bill
Discussion WALKERA 4#3 BELL HILLER MOD Project - For AGILE/Minimal Delay Cyclic response EQMOD Micro Helis 96 Dec 23, 2008 10:42 AM
Discussion Blade CP bell hiller mod owners inside Stealthpilot Micro Helis 21 Feb 21, 2006 01:48 PM
Mini-HowTo Bell-Hiller Mod (GWS Dragonfly, Hummingbird FP, Clones) Kosmic Micro Helis 6 Feb 08, 2006 12:13 PM
Simple T-Rex Tail Bell Crank Mod tomi Mini Helis 10 Apr 03, 2005 01:41 PM
Duzi Hornet Bell-Hiller Mod dgoslee Micro Helis 0 Jun 24, 2004 06:03 PM
