https://hobbyking.com/en_us/d2826-6-...ner-motor.html Nigel. |
See in my blog there is a set of pictures with explanations ... here |
Hi there,
I maidened mine last saturday. All was Ok except the fact that when the glider is correctly set to fly level with engine Off, she point her nose down as soon as i apply more than 50% throttle. It seems to be a common fact on the AXN Floater Jet / Clouds Fly - i guess a bad engine's thrust line setting ? The Cam and VTx joined the OSD in the plane on sunday. I still have to build her a landing gear and she will be ready for FPV sessions |
Edit: The nose over is common with airplanes with this design. The Bixler and like it are the same to one degree or another. |
May be re setting the thrust line may help - does somebody found the good setting ?
Thx |
Improves the thrust line by pushing the bottom out. Doesn't remove the nose drop totally but does improve it. |
Thanks a lot for your input pghern !
That's exatly what i was thinking to do too but as far as i could see on a friend's Clouds fly, the genuine motor's screws are rather shorts and don't allow to add enough washers to remove the nose drop. I may try to find longer screws but.. it may be difficult ! Cheers ! |
Hi, I've put my Axn together and I'm almost ready to maiden. This is my first plane so I'm kind of a noob. There is a lot of excess wiring in the cockpit, should I try to clean it up?
Finally, any tips/reminders before I take it out to the field, c of g, newbie mistakes, throws, flight characteristics to be aware of etc? Ps I've been practicing on clear view so I'm ok at flying. |
Cog should be located under the wing's spar.
Check that all the control surfaces move in the good direction (i.e. when aileron stick is pushed on the right, the right wing aileron must be raised, elevator up when you pull backward on the elevator stick,...). As it's a pusher, also check that the engine is rotating in the good sense and that the propeller leading edges are facing the front of the plane. Check that all the control throws are set at least with the values given in the owner manual. If not already done, i recommand to cut the foam used as hinges and to use some Blenderm adhesive tape to build your new hinges (Blenderm is a surgical adhesive tape made by 3M and sold in pharmacy or some RC shops). It allows to build hinges that wiil be way more soft and way more resistant than the genuine "foam molded hinges". Check tha all the control surfaces are set at the neutral position when your TX sticks are centered. Be careful : right from the box, the engine thrust line is no so correctly set. If you apply 100% power and throw the plane, she will dive A LOT toward the ground. The best advice i can give you is to ask a friend to launch the plane for you, nose parallel to the ground after you applied about 50% of power, then once the plane will be in the air, increase the throttle and be ready to use the pitch stick to prevent the plane to dive when you will increase the thrust. My Clouds Fly is fitted with a 2200mAh 3s 40c lipo + OSD + VTx + fpv cam and even with that additionnal load, she flies correctly with 50% of throttle so... don't be affraid not to fly full throttle ;-) One last thing : Don't trust too much the rc simulators (even if they are good tools for practice) and try to find a rc pilot to assist you in your first flights. There is no "press the space bar to fly again" in real life ;-) Oh, One last thing : secure the canopy with a rubber band , that will help not to loose it in the air. Have fun and tell us how was the maiden ! |
Maybe try a glide test before powered flight. Get a buddy to throw it, throttle off, to give u an idea if it's trimmed okay. It allows u to familiarise yourself with the controls with very little pressure or height to do big damage.
Ice Flight
Sleepy thread here...
Here's a flight from this morning:
It was FPV using a little Eachine 200mW all-in-one stuck in front of the motor pod. The video was from a separate camera under the wing, an 808 #16 D lens. -Chris |
