Sep 22, 2016, 01:26 AM
will this plane fly with 1000 kv motor and 1100mah battery ???
what is the best prop size if i try that way ???
Sep 22, 2016, 08:53 AM
Foam abuser!
crxmanpat's Avatar
1000kv is too low. Your prop is limited in size to 6". The lower the kv, the bigger prop you need. The 1100 battery is a little on the small side as well. These are the best items for this bird:
Motor - Turnigy 2826-6 2200kv
Alternate motor - 2212-6 2200kv (Baasically the same motors)
A good 30A ESC
APC 6X4E prop (or a generic equivalent like this)
And at least a 3S 1300 lipo. 1600 to 2200 is better.
Pat
Dec 27, 2016, 09:52 PM
great plane to build
My recent build.
I haven't installed any gear yet.
All the paint is water base acrylic from Walmart Craft Section, brushed on straight colors, no thinning...
Decals I comondeered from Sig Kobra kit.
Jan 24, 2017, 09:35 PM
Thank you Nic
Maidened this F16 today!
Flies like it's on rails! Rock solid even in windy conditions.
I'm using a Glacier 1800 mah, 3 cell battery.
Motor from Buddyrc.com is a SunnySky X2208 S-2000kv & APC 6X5.5.
The rudder has tons of authority! I can turn, then level back up using a small amount of rudder only.
The roll rate is mad!!! It will roll twice before any elevator input is needed.
Pitch up the nose slightly and it will roll 4-5 times before level flight...
Love it!!!
I installed the tip of a clear ball point pin so to see the receiver red light.
Thank you very much.
Mar 24, 2017, 12:06 PM
Sethorus's Avatar
cut the templates for the 120% version. Going with EPP(15, 9, and 3mm) in the vain of the Twisted Hobbies F22. Looking for a bigger tougher bird that will work with a 3 or 4cell. Once I get all the parts cut from EPP and know the weight, will start the hunt for a powerplant.
Mar 31, 2017, 08:02 PM
Sethorus's Avatar
parts cut and test fit. As shown weight is at 244g. I used 15mm EPP for the horizontal surfaces and 9mm for the verticals and undercarriage.
Apr 14, 2017, 07:13 PM
Sethorus's Avatar
a little headway with some color
Aug 22, 2017, 01:00 AM
Remote Controlled Crashes
gcok's Avatar
Flying on the race track
F-16 Tomhe on a drone racing track (4 min 55 sec)
Discussion Have any of you bought the F16 falcon air hog plane? ricktheshark Scratchbuilt Indoor and Micro Models 2 Jan 22, 2006 06:56 PM
Ripmax F16 Falcon : No manual Cubber Pusher Prop Jet Models 25 Jun 28, 2005 07:51 AM
WANTED Kyosho F16 Falcon EDF bmaaa Electric Plane Talk 1 May 18, 2005 12:22 AM
Looking for the "Old" Kyosho F16 Falcon Electric Ducted Fan bmaaa Aircraft - Electric - Airplanes (FS/W) 1 May 17, 2005 07:47 PM
