Feb 15, 2018, 06:13 AM
What foam are you guys using for these planes now? EPP and depron are so hard to find now. Has anyone successfully used DTFB?
Feb 16, 2018, 10:35 AM
Squall's Avatar
DTFB with the paper on is way too heavy for a good 3D plane, flimsy and more fragile with the paper off, but much lighter. Model Plane Foam is a good alternative.
Flying Foam still sells EPP....
https://flyingfoam.com/product/epp-10-sheet-bundle/
Feb 21, 2018, 05:24 AM
Build, crash...repeat
AleRRon's Avatar
Epp
GraysonHobby.com also has EPP for sale
Sep 14, 2018, 05:06 PM
Originally Posted by tallflyer
Ok here are some New Plans! For 2017...
No More Stick Mount for the front end!
There are so many New Motors that offer better power to weight ratio that are
smaller and can be mounted to the front end with just tape. (more Info coming soon)
Hi Tallflyer,
Still hoping you will post non-tiled plans at some stage and some specs for the motors that you mentioned.
Thanks so much,
Oli
Sep 20, 2018, 11:50 PM
Ok, turns out that when you open the pdf you can "save as" the image on the first page (or any page?) and it is in fact the whole sheet. I've attached it...
Sep 21, 2018, 09:30 PM
flyin' fool
goldguy's Avatar
Thanks, it's handy to have.
Nov 20, 2018, 10:25 AM
flyin' fool
goldguy's Avatar
Tiny version ...............… https://www.rcgroups.com/forums/show...hlight=tiny+3d
Aug 04, 2019, 04:54 PM
CNC cut Superslo 28 kits!!
Hello all,
With Tallflyers permission, I am pleased to announce that I will be selling CNC cut Superslo kits. All the kits will be made from 9mm EPP foam, and will include, carbon spars, push rods, control horns, motor mount (for the blue wonder motor). These kits will be white, so the decoration is up to you. These will be very nice kits and everything will fall together. The kits are $47, but if you preorder now, you will get it for $40. If you are interested, please PM me.
Aug 07, 2019, 06:42 PM
Hi guys,
Where do you get you 9mm and maybe 12mm EPP foam to make one of these...12mm is for a 36 inches span a say in this thread.
Thank you
paul
Aug 08, 2019, 09:10 AM
EPP is hard to come by now, but I have a supplier locally that i get mine from. If you want one, you may as well just buy a kit from me.
Originally Posted by Lutin
Hi guys,
Thank you
paul
Aug 08, 2019, 03:03 PM
Hi guys,
Thank you
paul
Lutin,
Wind Catcher RC sells Epp in thicknesses from 3mm - 2 inches in black and white, in #1.3, and #1.9 densities, and has carbon fiber on sale until the end of august. If you want to cut your own plane.
Video Slofly28 Superslo tallflyer Electric Plane Talk 2 Nov 15, 2008 11:01 AM
Sold Slofly28" Superslo kit tallflyer Aircraft - Electric - Airplanes (FS/W) 1 Sep 11, 2008 10:33 AM
Sold 1 Slofly 28 SuperSlo kit, 1 Slofly 28 Acro, 3 GWS Pico servos - $45.00 shawn595 Aircraft - Electric - Airplanes (FS/W) 6 Jul 25, 2008 12:26 PM
