Jan 23, 2009, 11:54 AM
John and Paul, I like your ideas I think I will do that, because I will probably muck up trying to cut the ribs.
Yay now I can sleep again.
Jan 23, 2009, 12:05 PM
Iīm the "Before Club"
carabin's Avatar
Hi Jeff
I donīt understand well if the problem is this , but I will do as well as in the pictures, so the cover (ultracote, monokote) is better, I have seen done in many wings.
John I have tried open the Coreldraw file but I canīt open the file , maybe my old CorelDraw, but I canīt see anything, my version is 8, maybe it is time that yours is more recent.
Carlos
Jan 25, 2009, 04:57 AM
Student of Ivan
mountainman2442's Avatar
Jeff,
Looking through my Beverley build pics I found this cropped photo that shows a"fixed" rib.
John
Jan 25, 2009, 02:26 PM
I've decided to do the above suggestion of making it a "J-beam" by gluing a strip of 1/8" square stock along the bottom edge of the profile (good thing its a flat-bottom). The top of the rib I am currently capping with two overlapping strips of 1/16" strips.
I'm also making servo pockets in the wings rather than use two big standard servos at the wing center with all that linkagey nonsense. I am putting 4 HS-81's in the wings.
I lent my camera out, so will have to wait a couple days for updated pics.
Jan 25, 2009, 03:09 PM
pentaxman's Avatar
Great build, now subscribed.
If you are looking for slow flight, may I reiterate the masters comments.
Build in lightness!
So minimise the use of Gorilla Glue and substitute balsa filler with lightweight spackle, it will make a difference.
I have built an IP Mosquito without the cuffs on the wings. I use Lipo packs and brushless motors and she is a real sweetie to fly. She comes in slower than a lot of the park fliers I see flying and retains aileron control right down to the stall which is really slow for a machine of its size.
Keep going!
Feb 01, 2009, 01:33 PM
Progress update...
I finished capping my ribs and sanded down the excess. After that I built the ailerons and flaps and started fitting the flap mechanism. As you can see I have built servo pockets in the wings that are flush with the bottom surface of the wing. For the ailerons the only protrusion from the bottom will be the control horn. And for the flaps the entire mechanism will be "inside" the wing just like on the plans.
I have dry-fitted everything and by making up some slotted blocks for the flap hinges, I can install the control surfaces after covering. I hate covering around protuding bits...
Feb 01, 2009, 02:35 PM
carabin's Avatar
Hi Jeff
It is a good solution to the problem, look very good, forward ever is less for the end...........
Carlos
Feb 02, 2009, 01:08 AM
East Coast subscribing..!
Great work Jeff,
thanks..
Bill
Mar 21, 2009, 12:57 AM
Sparky "Electrics Rule"
bobf's Avatar
How is built coming?
Apr 14, 2009, 11:12 AM
ARF Hater Club
tommyeflight89's Avatar
A bump for this!
I am considering a build project over the summer and either the Otter or one of the Shorts from Ivan caught my eye.
It is possible to get cut files fro both the 480 and 600 version, yes?
Apr 14, 2009, 02:16 PM
Originally Posted by tommyeflight89
A bump for this!
Tommy,
Yup I posted the 480 cut files in this thread (make sure you find the latest version later in the thread). MountainMan posted the scaled up 600 size files.
Jeff
May 04, 2009, 09:53 AM
build like there is no 2moz
wallis_100's Avatar
Hi Jeff,
I too have been building a twin otter 480 from Ivans plans.
Your making good progress, and i can't wait to see another one fly.
I maidened mine only last week and it flew straight off the board, so i guess yours will be the same. https://www.rcgroups.com/forums/show....php?t=1042352
i'm now looking at fitting floats as it has plenty of power, and i want to ty some water flying before i build one of Ivans minicats
scott
Jul 22, 2009, 08:44 AM
Ustabee supported Unabomber
countrygentleman's Avatar
Any progress on the build, Jeff? Tommy, did you ever decide to go ahead with some sort of summer build?
Jul 22, 2009, 12:09 PM
Nope no progress, sadly. RC modeling has taken a back seat to my social life since the end of of winter. I would like to finish it, so I'll probably resume the build next winter.
Jul 24, 2009, 12:12 AM
Boffin
rpage53's Avatar
So what's this thing you call a social life? Tell us more, its unheard of around here
Rick.
Link Ivan Pettigrew Planes - Build Threads and Videos LukeZ Scale Kit/Scratch Built 3481 Sep 18, 2018 01:48 PM
Build Log Yet Another Ivan Pettigrew Short Solent 480 MattZC Scale Kit/Scratch Built 622 Feb 21, 2017 02:50 PM
Discussion Ivan Pettigrew Short Sealand 480 -New Video Added flypilot Scale Kit/Scratch Built 79 Jun 07, 2008 12:33 AM
Discussion Slow Build Thread for RT models Ivan Pettigrew De Havilland Mosquito Gonzo007 Scale Kit/Scratch Built 13 Jun 01, 2008 06:36 PM
Beldone Twin Otter Buran Scale Kit/Scratch Built 8 Jun 21, 2006 07:18 AM
