esc/motor question - can I use any ESC with any motor? - RC Groups
Nov 14, 2008, 06:06 PM
I have a Greatplanes Electrifly brushless motor (http://www3.towerhobbies.com/cgi-bin...1&I=LXLWX6&P=3) and a Eflite 40A brushless ESC. Is it OK to use that motor with my ESC? Or do I need the same brand motor/ESC?
Nov 14, 2008, 06:13 PM
Wind blows
Laggard's Avatar
Any brushless esc will work with any brushless motor. Making sure you have a large enough esc is another thing.
Nov 14, 2008, 06:28 PM
That ESC will work fine for that motor, as the motor is rated at 18A max and the ESC will handle up to 40A.
Curt
Nov 14, 2008, 10:24 PM
Unregistered User
liam2317's Avatar
Yeah that ESC will work fine. If anything it's overkill. All you have to do is make sure that max current the motor can draw (in your case 18A) does not exceed the maximum amount of current your ESC can supply (40A).
Nov 15, 2008, 12:00 AM
Actually, the max current on that motor is 30 amps, and not 18. So the 40 amp ESC is a perfect fit...
Chuck
Nov 16, 2008, 12:43 PM
Got shenpa?
flieslikeabeagle's Avatar
I've heard claims from one or two flying buddies that they get better results with ESC and motor from the same manufacturer. But that has not been my experience at all - my experience is that a good ESC will work with any good motor, while a bad ESC will work only with some motors, if at all.
It makes sense too, there is actually very, very, very little difference between one brand of motor and another - they all use magnets and coils of wire spinning past the magnets. Only minor details differ. By contrast, while all ESC's do the same job, the software algorithms used internally may differ quite a bit from one ESC to another, and some are just plain better than others.
By the way, "bad ESC" doesn't necessarily mean "cheap ESC". I've been much happier with the performance of my cheap Suppo and inexpensive Turnigy ESC's than some of my much more expensive "premium brand made (mostly) in the USA" ESC's.
-Flieslikeabeagle
Oct 28, 2017, 05:10 PM
How about this: I bought a redcat Everest gen 7. Brushed motor, 2000mah nimh battery. Says Lipo ready. BUT, I I have an extra traxxas titan 550 12t brushed motor and an xl5 esc. Would that esc work in that receiver..?
Oct 28, 2017, 08:24 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
This forum is for RC electric airplanes , try asking in the RC electric car forum :
https://www.rcgroups.com/electric-power-cars-50/
go to the "Forum Tools" menu , and select "post a new thread" .
Oct 28, 2017, 10:43 PM
Wake up, feel pulse, be happy!
Piece's Avatar
ESCs and receivers are universally compatible so that should drop right in.
However, the truck's stock gearing might be set up for a lower Kv (i.e. higher turn count) motor - 20 turns is very common for 540 size stock motors - so you'll probably need to run the 12T with an appropriate pinion and keep a close eye on motor temperatures until you're sure the system is working safely.
Latest blog entry: My feet smell funny
Discussion Motor and ESC Question. Can I use this? redboat219 Dock Talk 1 Aug 16, 2007 06:52 AM
Discussion Can I Use A 3200 Kv Brusless Motor With The Stock Pinion And Gear On My Hb Cp2 ? agapornis Micro Helis 3 Jan 30, 2006 12:00 PM
Question Can i use any brand of Receiver with a Hitec TX ? martin_uk Radios 5 Jul 21, 2005 06:35 PM
Can I use any 17T car motor for Corona GoodHeli Electric Heli Talk 6 Aug 05, 2003 10:06 AM
