Nov 22, 2015, 03:12 PM
SPE .43 Repais
I just bought a used edge 540 with the SPE .43 in it. It had been sitting for a while. We got it running great then shut it down, the crank shaft now has a wobble. Likely a bearing or cracked piston rod. Does anybody repair or sell parts for these things?
Ryan
310-666-0188
Nov 22, 2015, 05:46 PM
Originally Posted by Rgromfin
"... We got it running great then shut it down, the crank shaft now has a wobble. Likely a bearing or cracked piston rod. Does anybody repair or sell parts for these things?... "
looks like you're in SoCal given your are code. There are a couple pilots, "Robert Petrosian" and "Alex Zayika that hangs out once in awhile at the Apollo Field. They both have had experience in repairing this engine. From the sound of it, it is most likely a bent shaft.
There is a couple shops that fix these engines as well (not local), but online.
Peace,
Steven Chao
Feb 21, 2018, 04:29 AM
Know any place where I can get a Pitts style muffler for the spe 26
Feb 21, 2018, 05:36 AM
Anything that fits the Zenoah G26 should fit the SPE26. And if you're at it already do yourself a favour and replace the Walbro carb on that engine, it comes with a 9.5mm Venturi (24/64) and if you fit a larger dia. carby (32/64 = 12.7mm is ideal) you can easily transform it from 'gutless' to 'acceptable'.
Feb 21, 2018, 11:48 AM
Thanks..I have a Walbro WT 257 on it.. is that good enough?
Feb 21, 2018, 11:53 AM
AMA 46133
SeismicCWave's Avatar
From playing around with my G23 and G26 I really like the Walbro WT813 (It says 813A on the carb). Of all the different carb that works the best for me at least on both the G23 and G26. It has an accelerator pump and that makes the throttle transition so much better. No hesitation compare to the stock WT643.
http://www.davesmotors.com/walbro-wt...y-engines.html
Feb 21, 2018, 04:50 PM
Yes, that's a great carb with a12.7mm Venturi, obviously been upgraded already some time ago.
Feb 21, 2018, 07:19 PM
A couple of things...
1. people comment without reading..., because Walbro carb is standard with this engine. So don't be stupid and start replacing carb for the sake of replacing.
2. Walbro make a variety of carb. I would not go and use the one that another 26 or similar size uses, just because they are Walbro. The Walbro carb that comes with it is an excellent carb. Specifically picked out for this particular engine.
3. The weakness of the engine is not from the engine, but from the ignition system. There are plenty of different after market companies that make replacements. You just need to know which market that your engine was originally was made for (octane level), so that the ignition was designed around. If you don't know know, you can ask someone who does know and readjust and figure out the proper sensor and ignition location.
Peace,
Steven Chao
213-268-1926
Feb 21, 2018, 07:21 PM
I used the DLE iginition system and fuel from Home Depot which is ethanol free and it works great.
Feb 21, 2018, 07:22 PM
do not invest too much $ into the engine. The later version has a much better internal counter balance.
peace,
Steven Chao,
213-268-1926
Feb 21, 2018, 07:24 PM
good for you.
AMA 46133
peace,
Steven Chao,
213-268-1926
ROFLMAO read between the line guys.
Feb 21, 2018, 07:27 PM
I got this engine along with the plane..so far 2 gallons and still kicking.. it has lots of vibration..
Feb 21, 2018, 08:02 PM
keep an eye for hairline crack on the engine mount and the prop hub. The QC on that engine varied greatly. The MFG eventually moved on to a new designed, named MLD. The MLD series was a far better designed engine. In my personal opinion, years ahead of the DLE series. The MLD was also capable of accepting minor adjustment to up the performance... it is neither here nor there.
I would not get the MLD engine now, unless you have access to parts.
Peace,
Steven Chao,
213-268-1926
Zenoah 20cc Electronic Ignition Gas Engine Review RichN Engines 88 Mar 26, 2013 11:29 PM
Sold SPE 26cc gas engine Hilde Aircraft - Fuel - Engines and Accessories (FS/W) 2 Sep 06, 2008 01:16 PM
Wanted MVVS 1.6 or Evolution 26GT 1.6 (26cc) gas engine Steve H. Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 28, 2006 01:26 AM
WTB good used 23-26cc gas engine Jim Walker Aircraft - Fuel - Airplanes (FS/W) 16 May 26, 2005 12:52 PM
F/S: 3W-28icc Gas Engine, Still In Break in!!! Extra 3D Aircraft - Fuel - Airplanes (FS/W) 0 May 21, 2005 09:12 AM
