kyosho curtiss p-40 warhawk
Building my first warbird. Was wondering about the CG for the Kyosho p-40? (I dont read Japanese) Was also wondering about ideas for two line fueling thru the cowling. and any other helpful hints would be greatly appreciated. Thanks
Just built this kit myself and am just waiting for my custom muffler to be delivered to complete, so havent CG'd it yet. The manual states CG should be between 95-105mm from leading edge of wing. Make sure you do this inverted with an empty tank. I will make mine slightly more nose heavy, just in case. What do you mean by 2 line fueling? Im probably gonna have the filler pipe hanging out from the 4 cowl flaps, which I have cut and bent outwards.
Here's my finished model. Just gotta CG it and set the engine up.
Can someone tell me the diameter of the wheels on this plane?
Thanks! another question!: what is the diameter of the wheel well?
Thanks in advance! |
Does this plane have split flaps?
It appears the new version does.... |
No prob. Wheel well diameter is 80mm. Mine doesn't have split flaps tho. Didn't know there was a newer version tho. Mines the SQS version. The VQ warhawk has split flaps and better detailing same with the CMPro one too.
Both EP and GP.
The GP will be released first, as I understand it. http://www.kyosho.com/eng/products/r...duct_id=104537 Exact same dimensions as the one you have. Some structural differences they say. 80mm wheel well is great for 3" wheels. A good size for grass fields. Thanks |
290 dollars oof.
I did not win that auction. Dang last-minute bidders.... |
Thread Tools | |
Similar Threads | |||||
Kyosho P 40 Warhawk | Moeller | Scale Kit/Scratch Built | 10 | Dec 23, 2007 10:14 AM | |
Discussion | P-40 Warhawk by Kyosho. Old and new compatibility? | Ventus 2000 | Fuel Warbirds | 0 | Mar 30, 2006 06:34 PM |
Guillow's CURTISS P-40 WARHAWK Conv. | justincgdick | Scale Kit/Scratch Built | 24 | Jun 03, 2005 08:05 AM | |
My new foamy Curtiss P-40 Warhawk | Digitalset | Foamies (Kits) | 11 | Mar 16, 2005 01:04 AM |
