Oct 29, 2008, 11:48 AM
Registered FFF Addict
larryross's Avatar
The CF2822 Brushless Motor
I think this is a remarkable little motor especially for the price $5.95. I have used it in several models. I plan on using 4 of them in my 8 foot seaplane. incase you are not famiruar with it here are the specs:
Tiny but mighty!
A well made and nicely finished outrunner. Excellent for small foamies and indoor shockflyers.
Spec.
Weight: 39g (with wire & sticker etc)
Shaft: 3mm
Motor Length: 46mm
Diameter: 28mm
Stator Size: 22x10mm
Suggested prop: 9~10inch
Voltage: 11.1v (3S)
Kv: 1200RPM/V
Data ;
Prop size: 10x5
RPM: 7100
Max Curr: 14.5A
Thrust: 710g (1.51lb)
Prop size: 10x4.7 SF
RPM: 6100
Max Curr: 14.5A
Thrust: 745g (1.64lb)
I think it would be interesting to see what it could power.
SHOW WHAT YOU ARE POWERING WITH THIS MOTOR.
How about a little Pro and Con discussion too.
Oct 29, 2008, 12:56 PM
frankyfly's Avatar
Larry it seams to have good spec.
I advice you to move your post to Power System theread and/or ask Dr. KIWI there.
I think he has reviewed this motor somewhere.
Franky
Oct 29, 2008, 01:11 PM
larryross's Avatar
Franky... I am not asking questions about the motor or seeking advice about it's use. I'm sure Dr KIWI has a brilliant review. I think this is in the appropriate area as scratch builders have a more diverse range of models than kit or ARF builders. And I have noticed a lot of questions on cheap power for scratch builts. As I said I thought it would be interesting to see what scratch builders can do with these things in real world modeling. Thanks for the suggestion though.
Larry
Oct 29, 2008, 02:28 PM
Build, fly, learn!
I am using the CF2822 on this 10oz. (280g) 3D trainer: the Owl-RT.
I am extremely satisfied with this motor on 3S with a GWS8040HD prop (current is < 10A).
There are a few things one should know before using this motor:
  1. The grub screws that hold the motor to the mount have a tendency to come loose. Once the motor is installed it's a good idea to use some Loctite on the grub screws, lest they should come loose in flight.
  2. It comes without a prop adapter. Shaft is 3mm.
  3. Mine came with some magnet dust/debris that prevented it from running smoothly. Once cleaned it's OK.
  4. The motor is wound DLRK and has a nice linear throttle curve.
  5. Cooling of the windings is very good.
  6. The C-clip that holds the shaft is of questionable quality, and breaks easily if not removed carefully.
Edit: I added a few pictures of the CF2822. It's a rather nice motor for $6!
Oct 29, 2008, 02:51 PM
larryross's Avatar
Very nice build ADB2. Thanks for the information on the motor. We'll make sure we loctite the grub screws good. I watched your video... great flying especially with the wind.
Oct 29, 2008, 03:09 PM
Build, fly, learn!
Thanks Larry!
BTW Dr. Kiwi reviewed an old version of this motor with a different kv. I lent both a 1200kv CF2822 and a 1540kv CF2812 to my friend Louis Fourdan for testing (he has a fully instrumented test stand and just about 200 props...).
I'll post here once I get some numbers from Louis.
Anyways with a 3S 610mAh LiPo I am getting around 10krpm on a GWS 8040HD (around 470g thrust and 40mph pitch speed) @ < 10A, which is ideal for my 280g 3D trainer.
Oct 29, 2008, 03:40 PM
frankyfly's Avatar
Pardon me Larry !!
GULP ..... I misunderstund your query.
Franky
P.S.: yes I mount it on my SLOSTANG (Link)
Oct 29, 2008, 05:00 PM
treefinder
springer's Avatar
I've got two of them (I'm into cheap!) one on a 42" blubaby usually 3s and the other on a PV2 (Parkflyer Pete variant) 2s. BB uses 8x6 sf prop and PV2 a 9x7.5 sf. Great fliers. So far motors are rock solid. Also got a cousin cf2812 (1545kv) on a Mike 3s and 8x6 sf prop. Just looked and the props are Haoye from HC (also cheap).
Oct 29, 2008, 05:45 PM
yardboz1's Avatar
Good idea Larry. As I'm fairly new at this I was always wondering what kind of motor I needed for planes I was building. Picked up 2 of these earlier this year because they were so cheap. Currently have one in my Infineon i3D and one in a 28" SilentMite. i3D is running on 2s1200mah lipos so it would balance.Waiting for some bigger 3s lipos to arrive and then we'll see what it does. I did notice that one sounded a little "gritty" so I cleaned it out and lubed the bearings. Runs really smooth now.
Sterling
Oct 29, 2008, 05:58 PM
larryross's Avatar
Originally Posted by frankyfly
Pardon me Larry !!
Franky
No worries Franky I too often read over things and miss the jest. BTW I agree with Kdahlhaus that is the best looking slostang I've seen.
Oct 29, 2008, 06:06 PM
larryross's Avatar
Very happy to hear from fellow cheapo. Thanks for the post.
Oct 29, 2008, 06:09 PM
larryross's Avatar
Sterling
Was it difficult to clean up? I like the Infineon. Thanks for the post.
Oct 29, 2008, 06:31 PM
My plans are in my blog
Rusty-Gunn's Avatar
I've used the version that spins a 7 inch prop, and enjoy the performance I get from it. I've even ordered two more (got them a few weeks ago), and will put them in some planes I'm working on. Excellent motors.
Oct 29, 2008, 06:39 PM
larryross's Avatar
I love your toon planes. As soon as I can I am going to build them all. Guess what motor I will use. I would still like to get the drawings for the SkyBaby. I'm collecting them and running them through a CAD and vectorizing them so I can enlarge them. Thanks for stopping by and posting.
Larry
Oct 29, 2008, 11:54 PM
Rusty-Gunn's Avatar
I apoligize. I'm rather slow with building my planes lately, not much time it seems. When I worked night shift I had plenty of time (most of the night) but now that I'm day shift, this has changed.
For Sale EMAX CF2822 Outrunner Brushless Motor SROlmeda Aircraft - Electric - Power Systems (FS/W) 0 Oct 08, 2007 07:58 PM
Sold Emax CF2822 Brushless Motor ShokWaveRider Aircraft - Electric - Power Systems (FS/W) 0 May 21, 2007 11:27 AM
Sold Emax CF2822 brushless motor darkside212 Aircraft - Electric - Power Systems (FS/W) 0 Nov 08, 2006 07:54 AM
Jeti brushless ESC & Ikarus brushless motor albatros Electric Plane Talk 1 May 06, 2001 04:33 PM
tiny brushless motor and i mean tiny tiny Spin_Doctor Electric Plane Talk 1 Apr 30, 2001 04:07 PM
