Oct 18, 2008, 07:23 PM
Just here to fly stuff
LeadSled's Avatar
Model - EDF Unit - Motor - ESC - Speed!!
I posted in another thead that we should start a "speed" thread.
To do this a pilot would post:
- Model
- EDF Unit
- Motor
- Batteries
- ESC
- Speed
- How you measured the Speed (with link to Video)
- Other supporting information (wind conditions, temp, and other information about your plane)
This thread is for those that want to show off their planes, and for those that want to look at setups they can use
(My next post will be about my Spark)
Oct 18, 2008, 07:28 PM
LeadSled's Avatar
Spark - October 18th
- Plane: Composite ARF Spark
- EDF: TJ100
- Motor: 1515 1.5Y
- Battery: 8S 3700mah
- CC HV110
- Speed 136.5 mph
- Doppler (see attached picture)
This was taken from a level speed run. I had taken the plane up run a lap and then did the run. There was no wind, see picture of the flag at our field. Here is a link to the video:
https://www.rcgroups.com/forums/show...5#post10767164
This is a great plane.
Oct 18, 2008, 08:54 PM
2024 EDF Jet Jam, June 6-8
Robert Belluomini's Avatar
Sled,
Looks great! How is the gear holding up?
Is there a reason you did not use the supplied battery tray?
Bob
Oct 18, 2008, 09:23 PM
- Plane: Vector II
- EDF: DS 51-3ph
- Motor: Nue 1515 1.5Y
- Battery: 10S 4000mah
- ESC: CC HV110
- Speed 187mph up wind 192mph in a shallow dive
- Measurment: Doppler
She still has potential to go faster
Oct 18, 2008, 09:24 PM
LeadSled's Avatar
Hey Bob. The battery tray did not let me move the batteries forward enough to get the correct CG, and it was easier to just use the velcro. The main landing gear legs that came with the SpringAir 301s bent after each landing.
I got a set from Tam (4mm, 2 spring), and they work better.
Oct 19, 2008, 02:56 AM
Tamjets's Avatar
I got 3 flights with the Spark and 3 with my new 1:8 scale F-16 Thunder Bird.
No video today because I'm flying.
Help! EDF unit + motor application assitance requested Hepdog Electric Ducted Fan Jet Talk 4 Aug 25, 2007 01:26 PM
Sold Het F-18 Edf With Motor,esc,fan,servos,and Battery JETWASH Aircraft - Electric - Airplanes (FS/W) 3 Oct 14, 2005 08:49 AM
FS: Kyosho EDF unit and motor. twinster2 Aircraft - Electric - Airplanes (FS/W) 1 Feb 16, 2002 01:39 PM
Looking For a Speed 400/480 EDF Unit... Demon-Leather Aircraft - Electric - Airplanes (FS/W) 1 Jan 18, 2002 04:13 PM
Brushless motor/ESC for EDF Magnaflux Aircraft - Electric - Airplanes (FS/W) 2 Oct 25, 2001 07:49 PM
