Oct 09, 2008, 06:45 AM
Mr Clean
FTIR's Avatar
BH Models P40 .60 info
Here are the pictures I promised. I will try and post more as I build the plane but will need a little time along the way. If you have info from your own build feel free to help us out.
In general I am happy with what a received. It has a nice scale look but is covered in PVC printed covering. I hope it will stay on the model. It is not quite on par with BHModels T-28 but looks great from about five feet or so. The actual construction looks very well done so the model should hold up to some great flying. The other item of concern was how the wings are attached to the fuse. It will take some work to transport this plane. You will have to undo six screws and unhook the retract servo to get it in most vehicles. Four screws at the fuse and two at the ends of the wing tube. The retract servo is mounted in the fuse and not on the wing. Fully sheeted was a nice surprise. Pre installed control rods. Flying Tiger, Girl, and pilot name are stickers.
They have the engine mounted at an unusual angle so I think I will be changing that, There is side thrust built in but I couldn't measure any down. If you look on the box it came in you can see the cylinder head of a .91 sticking out on the right side.
More later... Enjoy the pics.
FTIR
Oct 09, 2008, 07:07 AM
ndb8fxe's Avatar
Thanks for showing us your assembly. What do you plan on using for power?
Oct 09, 2008, 08:00 AM
man looks good can't wait to get one. I have heard all about the split wing set-up and the way they want retracts installed with servo in fuselage. What are you gonna do? I have either a y/s .91 or os .91 to put in mine when I get it.
Oct 09, 2008, 08:52 AM
Mr Clean
FTIR's Avatar
Engine
ndb8fxe :
I will be using a Magnum .91 four stroke and Futaba 2.4 radio equipment.
Mech79:
Not sure about the retracts yet. Maybe LADO retracts are in my future.
FTIR
Oct 09, 2008, 09:17 AM
I will tell you what, ever since I got my pair put into my VQ P-51 it think they are great and hasle free as long as they don't bind. I will probably get a pair for mine as well. Less expensive and easy to deal with.
Oct 09, 2008, 09:42 AM
ndb8fxe's Avatar
Where is this model available?
Oct 09, 2008, 10:19 AM
Mr Clean
FTIR's Avatar
I bought mine from Hobby People.
FTIR
http://www.hobbypeople.net/gallery/159560.asp
Oct 09, 2008, 10:29 AM
mike early's Avatar
That hatch setup would really help an electric conversion...I like nitro!
Oct 09, 2008, 10:40 AM
mike early's Avatar
what is the diameter of the spinner?
Oct 09, 2008, 10:44 AM
Mr Clean
FTIR's Avatar
A few more pics, checkout the hello, guess it was the builder at the factory.
Mike:
Not sure on the spinner diameter, I will try and check later.
FTIR
Oct 09, 2008, 11:03 AM
crazy8s's Avatar
Mike,
It is around 3 1/4 inches. It should be slightly larger to match up with the diameter of the cowl a little better though. But overall not bad at all.
Oct 09, 2008, 12:23 PM
mike early's Avatar
I've got a few 3.25" spinners. Hopefully they'll work.
From the photos of the instruction manual, I cannot tell if the front of the 4-stroke will be in front of the cowling "mouth" or not. Looks close. If there is enough room, I'll certainly mount mine 180º inverted.
Oct 09, 2008, 12:32 PM
Mr Clean
FTIR's Avatar
Mike:
After looking at the model I think the four stroke will fit 180 deg and stay in the cowling.
FTIR
Oct 09, 2008, 12:36 PM
mike early's Avatar
damned good news. what engine shall you use?
Oct 09, 2008, 09:50 PM
Mr Clean
FTIR's Avatar
I have a new Magnum .91 four stroke.
I started the build tonight and I think I am really going to like this plane. I will post pics as I go.
FTIR
For Sale BH Models 61" wing span 60 size KATANA Flyextreme Aircraft - Fuel - Airplanes (FS/W) 2 Sep 20, 2008 03:54 AM
Alert vq models p40, good or bad???? fldmshlschroe Fuel Warbirds 25 Dec 06, 2006 10:03 PM
Mountain Models DL-60 sighting ! Orphic_Egg Hand Launch 16 Aug 03, 2005 12:15 PM
World Models Velox 60 Axified with 4130/20 and Gp3300 Magna Sport Planes 12 May 13, 2005 05:10 AM
Fs Vq Models P40 Kittyhawk Nib Pilot44 Aircraft - Fuel - Airplanes (FS/W) 8 Feb 07, 2005 05:46 PM
