Sep 29, 2008, 02:00 PM
P. Tritle's Avatar
Build Log
Another 1:8 Scale Super Cub
Got started working up another 53" Super Cub. This one will have a stock landing gear, but will be equiped with all the STOL toys.
It all started with making up the bowed outlines, then building up the tail section.
Sep 29, 2008, 02:09 PM
pie hopper
toyjunker's Avatar
Originally Posted by P. Tritle
... all the STOL toys.
Slats, flaps, VG's and droop tips?
What else am I missing... VG's on the H stab? Any hints or do I have to wait the usual three or four hours for you to finish this one?
The popcorn is in the microwave!
Dave
Sep 29, 2008, 02:12 PM
P. Tritle's Avatar
Moving On To The Fuselage
The fuselage frame up was next.
Now, when it came to joining the side frames I found a foul up on the plans that will bite you later if not corrected.
When putting in the wing bolt plate and former F5 at the back of the cabin, the location is correct. But, the front header is shown in the wrong location. To insure the wing will fit, the aft face of the front header F4 should be located 7 1/32" forward of the front surface of F5.
I don't know how the plans got out wrong, and so far no one has called me on it, but the original drawings have since been corrected and all the Short Kits going out from here on will show F5 in the correct location.
Sep 29, 2008, 02:16 PM
P. Tritle's Avatar
Adding the Details
The next step was to build up the main gear assembly, then add all the stringers and outfill, followed by the boot cowl.
Sep 29, 2008, 02:24 PM
P. Tritle's Avatar
And Then, it was onto the Wings
Construction began with the outer wing panels.
Also, there has been a bit of confusion with gluing the two piece main (Part #A1 & A1A) and rear spar sections (Part #A2 & A2A) together. The spars are over 24" in length, and since the cut sheets are only 24" long, the spars had to be cut in two sections. A diagram for that has also been added to the plans to help clear up ant further confusion as to how they join up.
Sep 29, 2008, 02:29 PM
P. Tritle's Avatar
Dave, No droop tips, just the flaps and LE Slats in front of the ailerons. That'll slow things down enough at the projected flying weight of under 16 oz. to make the controls quit working Just kidding of course. The slats helped lower the stall speed a bit, but mainly keep the ailerons at least partially effective at low speeds and high AOA.
Meanwhile, get the popcorn in the Microwave, it'll be finished in a minute
PAT
Sep 29, 2008, 02:32 PM
P. Tritle's Avatar
Joining the Panels
With both panels built, sanded to shape, and the flaps and ailerons hinged, it was time to join the panels. The dihedral braces "egg crate" into the panel assemblies and aligh with the front spar to aset up the proper dihedral angle without having to block the tips. Once glued in, the center section was built up to complete the basic wing assembly.
Sep 29, 2008, 02:35 PM
P. Tritle's Avatar
The First Dry Run
With all the major framing done, the big pieces were put together to find everything fit and aligned nicely. From here, the servos and control systems will be fitted and installed.
PAT
Sep 29, 2008, 02:43 PM
Veni Vidi Volavi
Brian Allen's Avatar
Pat
Quick question for you. Does the dimension bugaboo for Former F4 also appply to the 1/8th scale L-4 that you did recently? I reread the build thread and can not decide if the L-4 was based off of the Super Cub design at all or was a completely new design.
Nice work on the Super Cub. Whats next??
Brian Allen
Veni Vidi Volavi
I came Isaw I flew
Sep 29, 2008, 08:41 PM
P. Tritle's Avatar
Brian, The L-4 design is completely independant of the Super Cub, so it's not an issue. Also, the Super Cub is a one piece wing where the L-4 panels plug into the cabin sides.
Funny thing, this is the 3rd Super Cub built from these plans, and I don't recall it being a problem on the first 2 -- unless I measured the wing and located F4 accordingly, which is how I did it this time. Then after the fact, noticed something didn't look quite right and caught it after the fact.
PAT
Sep 29, 2008, 08:43 PM
P. Tritle's Avatar
Finishing the Wing
Got the servos mounted and the cables run in for the flaps and ailerons. And with that, the wing is ready to cover.
PAT
Sep 29, 2008, 08:48 PM
P. Tritle's Avatar
Finishing the Fuselage Control Installation
The servos are mounted up and the elevator pushrod is in. The rudder will be pull/pull, so will run in the cables and mark the location where they exit the fuselage for reference, then mount up the drive system and she's ready for cover.
PAT
Sep 30, 2008, 01:06 PM
Veni Vidi Volavi
Pat
Thanks for the info.
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Sep 30, 2008, 02:58 PM
Neophyte hacker
portablevcb's Avatar
So, is this one for you?
Couldn't stand not having another Super Cub could you
charlie
Sep 30, 2008, 11:04 PM
AmpAce's Avatar
A guy just can't have too many Super Cubs! I've gotta get a replacement for my old well used Dare one built soon. It has over 165 hours on the meter now.
Thanks Pat, for the heads-up on that front header location.
AmpAce
Build Log 1/3 Scale Super Cub - Balsa USA G202RC Giant Scale Airplanes 516 Jun 07, 2016 06:17 PM
Help! Hangar 9 1/4 scale Super Cub discontinued? Electric Mike Giant Scale Airplanes 27 Feb 26, 2010 06:27 AM
For Sale For Sale; Dynaflite 1/4 Scale Super Cub Kit Warby Aircraft - Fuel - Airplanes (FS/W) 6 Mar 18, 2006 12:14 PM
Wanted Balsa USA 1/3 scale Super Cub kit NIB. Raymac Aircraft - Fuel - Airplanes (FS/W) 1 Dec 23, 2005 12:30 PM
Looking for a 1/4 scale Super Cub kit number1cop Giant Scale Airplanes 8 Aug 19, 2005 02:11 AM
