Nov 21, 2016, 02:54 PM
welcome..dean xt worked well for me for a long time deans or t plugs where hard to unplug when needed..
Jan 14, 2017, 01:48 PM
mkpatrick
Running my tank today produced a problem.
Its been running fine.
But today, the left rear drive sprocket wheel, that drives the track seems to be stuck. It won't rotate. In a power off condition, the other wheel can be rotated. I did that slowly and carefully to not cause any damage.
But this left one will not rotate and the tank won't go straight. It just pivots like the wheel/track is jammed.
What should I check first? Is this an indicator of something serious?
M
Jan 14, 2017, 02:41 PM
Plastic or metal gearbox?
Just curious.
Jan 14, 2017, 07:47 PM
mkpatrick
Just curious.
Metal with metal tracks.
Jan 15, 2017, 11:27 PM
mkpatrick
It appears one of the gear boxes is in bad shape. It jammed. When I removed the electric motor, I still couldn't rotate the gears. So I worked them loose. Put it back together, it ran for a 20 seconds or so and locked up again.
I did notice that some of the teeth on one of the gears is pretty damaged. I think I need another left side gear box.
Do they come individually like that?
Where do I get gear boxes? I can find none for the M41A3.
Any lubrication recommended? For example some vaseline? These gears look very dry.
Jan 22, 2017, 01:14 AM
HeavyCruser9's Avatar
try Tankarmy here in Australia he does a full range of parts. [URL="http://tankarmy.com/heng-long-tank/index.php/116-rc-tank-upgrade-parts-c-50?osCsid=e2abqv3u480g3joiqb0bk20gs0"]http://tankarmy.com/heng-long-tank/index.php/116-rc-tank-upgrade-parts-c-50?osCsid=e2abqv3u480g3joiqb0bk20gs0[/URL
He does gearboxes in pairs but it might pay to get a upgraded set while you have the tank in bits...
I am getting a HL M1A2 shortly that I will be giving some upgrades...cash permitting and a full OZ army camo job.
Cheers Bruce
Jan 22, 2017, 01:16 AM
PS try white lithium grease you can get it in a spray can with the little tube attachment at auto parts stores usually found on the shelf with stuff like WD40 and the like.
Jan 22, 2017, 02:11 AM
mkpatrick
White lithium grease. OK
So I bought this tank with the metal tracks and metal gear box. I was warned to not lube the gear box. I don't know why.
Is one metal gear box as good as another? Or are there better ones? If there are better ones, which ones are the best?
I just ran the tank around on the floor and sometimes over things but nothing that would be not scale for a tank to attempt. What sort of action will wear these gear boxes down?
Jan 22, 2017, 02:38 AM
for lube id use Zmaxx its a micro lubricant.. the metal will soak it up will not attract dirt as fast a white lithium does.... just a few drop on things that touch..
Jan 24, 2017, 09:32 PM
mkpatrick
OK so its time to buy a gear box for my M41A3.
Where is a good place to buy them in the US?
I look on Ebay and I see all sorts of gearboxes. But they don't specifically say what tank they are for.
I see Heng Long Short Axis metal gear box.
I see Long axis.
Some look nice with anodized parts but I do not know which one to get for the M41A3.
Can someone let me know which metal gearbox will work?
Would this one work?
http://www.ebay.com/itm/1-16-HengLon...4AAOSwT4lWRcRg
M
Jan 25, 2017, 10:17 AM
I see Long axis.
M
Why not phone up IMEX and ask them?
Jan 25, 2017, 05:06 PM
mkpatrick
Is IMEX in the US?
I will google it.
Jan 25, 2017, 05:12 PM
mkpatrick
They are in the US. They have a few parts for this tank but not what I need.
Not sure they will help me for a tank I bought elsewhere.
Nobody tuning into this thread has replaced a gear box on a M41A3?
Jan 25, 2017, 08:18 PM
Did you phone up IMEX and say to them "Which of your gearboxes fits my M41A3?"
Jan 25, 2017, 08:39 PM
mkpatrick
On the web site, they had none available.
I did not call them.
Mini-HowTo Heng Long Tiger Modifications & Upgrades HoverBovver RC Tanks 385 Jun 27, 2019 04:18 AM
Help! looking for heng long mad truck parts thorpe31 Off-road Cars 23 Apr 13, 2014 11:38 PM
Heng Long RC Tiger tank CarreraGTSCS RC Tanks 23 Aug 04, 2010 05:41 AM
Help! Anybody got Heng Long Tiger spare parts? jonathanm RC Tanks 3 Feb 14, 2008 06:00 AM
Question Fuel tank problems Claire Control Line 3 Oct 03, 2006 06:55 PM
