Feb 01, 2007, 01:46 PM
Heli Bouncer
Looooeeee!'s Avatar
Alfredo,
If it's a rx. from a 2 motored bit car there's really no need to change anything, I've used both my own hand wound actuators and the commercial ones using these radios.
Looee
Aug 25, 2007, 12:09 PM
Don't leave it Stock
mrfliboy's Avatar
Quick Junior Bit style
Built from:
Gordon Johnsons Quick Junior plans
Chariot Bit receiver and transmitter (stock)
Pager actuator (pull/pull)
GB04 motor/gear box
AUW 16 grams w/lipo
Front yard flights were wonderful, saving it now for the indoor season.
Nov 15, 2007, 03:57 AM
Peterfly's Avatar
Modifications to Tx: Replace 2 AA battery by 9V battery, add 5V voltage regulator ( 7805 ) for TX IC, re-wiring control button.
Modifications to Rx: Cut and sand some parts to lighten weight from 1 g to 0.6 g and add smd transistor for driving motor.
Antenna modifications: change antena to 0.5 m long.
Construction material:
Wing and tail from Depron foam slice to 0.5 mm thickness.
Body from EPP foam
Tail boom re-inforce with splitted carbon rod.
Range of transmission: 20 m.
Other details:
AIRPLANE
WS: 15 cm.
AUW: 3.2 g.
Motor: 4 mm.x 8 mm. pager motor from mobile phone
Gearing: direct drive
Prop: picco-z tail prop.
Battery: 30 mAH Fullriver
Actuator : 4 x 8 mm pager motor's coil and magnet
Notes: I can't remember which mobile phone's brand for this motor. The motor heat up, it has not enough power for the prop. to maintain driving force, the plane lost altitude. I'll try another motor in this size( 4 x 8 mm ) maybe some can, else change to 4 x 12 mm certainly enough power and the AUW slightly increase to 3.4 g. However others part can lighten down such airframe or batterry connector.
This plane I'ld like to call it " Chickabit ". My english language does'nt strong, how do you think about this name?
Here is the video https://www.rcgroups.com/forums/showthread.php?t=772353
Nov 15, 2007, 09:45 PM
FFFlier's Avatar
Nice plane Peterfly,
I've never heard of a bitcar with a 1 gram stock rx before. What kind of car is it? How did you lighten it by the way?
Thanks for any details,
Bill
Nov 16, 2007, 04:26 AM
Peterfly's Avatar
Thanks for your admiration. It's just only innocent and lovely not too nice
So I'll tell you its original brand is "Sound & lights" from China. I'm not surely its stock weight is 1.2 g or 1 g. I lighten it by remove component of voltage stir-up circuit and cut its PCB part off, sanding back side of the remaining PCB, cut the excess part of tuning coil.
Feb 08, 2010, 11:37 AM
starscream4002's Avatar
well here is my bit plane...I know it's not so cool but it "WORKS" and I guess it is worth posting in this thread
Electronics:
brand of car:rally racers
modifications to TX: none
modifications to RX:longer antenna, motor wires attached to turning output on RX and actuator wires attached to motor output on RX.
antenna mods:19" antenna for RX
the plane is made out of depron
Airplane:
WS:25cm
motor:X-twin motor
gearing:direct drive
prop:X-twin direct drive prop
battery is a fullriver 40mah
the model is a cessna 152 made from 3 view from this website:
http://richard.ferriere.free.fr/3vues/3vues.html
EDIT: pic lighted up and posted by slider,thanks slider
happy flying
SS
Feb 08, 2010, 01:21 PM
Slider2732's Avatar
I lightened that rather dark pic for ya
Congrats !
Feb 09, 2010, 01:18 PM
thanks
Jun 18, 2010, 08:00 AM
AMARILLO1978's Avatar
bit problem...
hello I do yesterday the tx mod with 7805 vreg and caps and give me 4.92 v. I conect it to pin 9... but the range still in 12 feet or less in the stock car with 1.2 ni-cd.....
this is what I do in the TX..... please someone tell me why I did not have more range...the tx seems that no have cripped cap...
Jun 19, 2010, 12:43 PM
lengthen the RX aerial(RX antenna) and try a "9 volt battery"
Jun 22, 2010, 10:21 AM
I enlarge the RX antenna and 9 v. bat in the TX and itīs working but go forward by pulses.... go... stop... go.... stop.... go....stop... Now I will try with single 130 mah lipo inside the car...
Jun 23, 2010, 04:40 AM
you must be sure that the wire connected to the antenna is the stock length and isn't touching anything
SS
Jun 23, 2010, 08:22 AM
SS... problem solved by now.... the problem was "low bat" I recharged the carīs stock batery and gooooo.... thanks I donīt measure the range go side to side of my livingroom near 40 ft. sure go far away
