Sep 16, 2008, 09:53 PM
Any way to turn off ESC low voltage cutoff?
My Castle Creations Phoenix 45 ESC seems to cutoff sometimes when the battery voltage decreases, but I would like to deactivate it. It does not show how to do this in the instruction manual. Is there any way to hack it?
Sep 16, 2008, 10:32 PM
Mad Max meets the Thinker
Cyberman's Avatar
There is a significant safety issue involved in doing this. You do not want to drop the battery voltage too low or the batteries will be ruined or worse they will catch fire explode etc. Lithium ion cells become unstable if you abuse them. NiMh should never be taken fully down either, they will simply stop working or have no capacity. You should check your cell impedance and how you are using them if the LV cut off is kicking in. You might be able to adjust the LV cutoff it I believe however, again it's more likely you are abusing your batteries too much and it's kicking out because of that.
Sep 17, 2008, 04:00 PM
We want... Information!
Bruce Abbott's Avatar
You can set it to cut off at 4V (follow the instructions in your manual). Combine this setting with 'Soft Cutoff' and it won't cut until there is not enough voltage to operate the ESC!
Don't even think about doing this if you are running Lipos...
Sep 17, 2008, 05:04 PM
Oh, thanks guys. I forgot about the 4v mode. That should work good.
Sep 17, 2008, 05:37 PM
You probably just want the soft cutoff instead of the hard cutoff that is the default.
Then whatever you are powering with the ESC will just loose power until you give up
Bruce
Oct 04, 2019, 04:25 AM
Low voltage cut off
i recently purchased a hobby wing max 10 sct, and i am trying to run a 7s NIMH in it. this should work but it only goes for about 15 seconds and then cuts out. after this the esc flashes red, red, red, red continuously, the manual says that this is low voltage cut off but i am not sure how to turn this off.
Oct 19, 2019, 04:35 PM
I don't want to "Switch Now"
pmackenzie's Avatar
This one?:
https://www.hobbywingdirect.com/prod...nt=20187925828
Instructions say to disable low voltage cut off when using NiMh packs.
Can be done with or without the programming box
https://cdn.shopify.com/s/files/1/01...40967152689469
Discussion Dynam ESC -- low voltage cutoff for lipo batteries Ben_Goh Power Systems 1 Jul 04, 2006 12:10 PM
Question Hyperion ESC low voltage cutoff Elite Power Systems 5 Jun 29, 2006 05:03 PM
What happens when a Lipo hits the esc low voltage cutoff? Rackey Batteries and Chargers 7 Jan 05, 2005 09:27 AM
ESC Low Voltage Cutoff Sierra Flyer Parkflyers 4 Jun 13, 2003 10:21 PM
ESC Low Voltage Cutoff and Li Ions Bill Glover Power Systems 22 Nov 12, 2002 10:13 PM
