I would suggest taking time to calibrate and test. Test every possible scenerio that you can imagine in the RTH. Set up your plane so that your plane responds exactly how you want it to respond. Read the manual (several times). "Hey, this is what you do; You might as well know what you're doing"... I love my ET... |
Well I have good news to report. I replaced the Corona RP8D1 receiver with the Futaba PCM R149DP. Setup the failsafe for the Carlyle method. Then I ran the servo wizard with the on screen menu and now everything works great. No more glitches. It works 100% in RTH using the Carlyle method or if I turn the transmitter off and it also works both ways wile I run the simulator. So it looks like the Corona RP8D1 receiver was the problem and just doesn't play nice with the ET OSD. Now I have to reinstall everything back into the plane and test again but it looks like problem solved.
Thanks for the help. Sam |
Glad it worked!
-Mike |
Graphic Error 0D0000
Hi Bill,
I have a new issue, "Graphic Error 0D0000", but as you can see in the video, nothing to disturb the guardian, only a cool flight in a very cool day. I get this twice in my last 5 flights, the problem is that when it happens, EagleEye get completly crazy and change RX every half second. So the Trakking antenna also run crazy. Fortunatly in this video the plane is returning and arriving to the landing point. Imagine this with the plane far away. I am running the last 10.04 version. Any idea? http://www.youtube.com/watch?v=rx-DPRAqfq0 Tku Eric |
My Futaba R149DP works great on the bench so far and I am now modifying it so I can monitor the rssi but I still have to get a buffer. |
I think it is related to your camera. |
Hi everybody i want upgrade firmware 10.4 for my another airplane but i use fy20 for this airplane it will problem ??? or i can fly firmware 10.4?
What kind of elogger do you have ? I got the v3 and i am not using the battery backup cable maybe thats the reason..... |
"Graphic Error 0D0000", was put in their just for Bill, in the new software it is removed so when you get the gliches the "Graphic Error 0D0000", will no longer show up. |
Nabazul brings up a good point.
Lets review the issues that we have encountered with firmware versions above 10.4. I think it was Wakahere that had the speed microsensor issues that ended up being a poorly aimed pitot tube. *edit* it was the kubiaks https://www.rcgroups.com/forums/show...postcount=7156 I can't think of any other problems that have come up. can anybody else think of something? -Mike |
No Beta version available
It looks like 10.4 is the release version
& there is no Beta version available at this time. http://www.eagletreesystems.com/Support/apps.htm I was feeling bad for not testing the beta for Bill. I've been flying 10.4 for quite some time now and have been very happy with the performance. |
Thread Tools | |
Similar Threads | |||||
For Sale | BRAND New CP Pro/with extra battery | stgtech2 | Aircraft - Electric - Helis (FS/W) | 0 | Sep 06, 2006 09:35 PM |
New eolo pro glitches with cc60 | aschen | Electric Heli Talk | 24 | May 20, 2004 08:12 AM | |
FS New Piccolo Fun with bearing upgrade and HA tail motor | Bud Morrison | Aircraft - Electric - Airplanes (FS/W) | 1 | Mar 21, 2004 07:32 PM | |
For Sale: NEW Pic Pro rotor head with stiffening mod | Eco8gator | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 02, 2003 09:16 PM |
