Max! Erll, I have received my bearing for my Radian but after I had them on order I began to really ting it through, The bearing are not bad and I won't change them until they are bad, so I just will wait until they do go bad. Have a good day and keep dry! Chuck
Occasional non-power up of system RX
Hey guys I just wanted to toss this out as I have seen a few folks on here that said they lost radio contact.
That has not happen to me but....I have had the following.. 1. On several occasions I have plugged in the battery pack to the plane and had no power up at all, as if the battery was disconnected. In the past if that had happen on anything else I had found a bad battery connection, Not so here, has happen with several packs and I have checked them all for poor connections. 2. I have had the OEM 30 amp ESC stop applying break. Since that happen I did not take a chance on it and have replaced it with a CC Thunderbird 45. The non power up has happened with the CC esc as well so I'm thinking this is a RX issue. With that said I haven never lost signal but since I am a die hard Airtronics fan I'm pulling the OEM RX and switching over to my Airrtronics radio and RX. Again just throwing this out. Mike R |
Radian Contest!!!
ALES style Glider Contest only using Radian XL, Radian, and UMX Radian. $10 entry fee per event - $30 max.
Just 3 weeks away!!! Saturday May 27th and again on Sunday May 28th! Fly one day or both! Just as long as its a Radian and you have a good time!!! |
