Aug 26, 2008, 02:03 PM
Pinch Test for High end or Low end settings ??
Hi All,
Is the " pinch test " applicable for High end needle settings or Low end needle setting ? I am a bit confused, as in some article its explained in the High end needle setting section while some in Low end settings.
I have both Car and Aircraft engines...
Pls clearify...
Regards,
Justin.
Aug 26, 2008, 02:55 PM
good listener
Just low end for me on my 2 cycle stuff. I "think" I can still hear well enough to set the Hi End with a tach and my ears.
Aug 26, 2008, 05:45 PM
Pinch test can be used for either/both needle setting as covered in considerable detail in the tuning sticky at the top of forum https://www.rcgroups.com/forums/showthread.php?t=205602
Steve
Aug 27, 2008, 12:48 AM
downunder's Avatar
It's more suitable for the low end because of the time it takes to get a reaction. At full throttle the engine is using fuel so fast it can be difficult to hear any difference before it starts to die from lack of fuel if it's even close to being tuned correctly.
Aug 27, 2008, 02:45 AM
Perhaps I just have good ears then . I've always used the pinch test as the last check on the top end before flying, just to be confident that nothing's changed and I'm still running a little rich.
OTOH I'm not much of a needle twiddler and tend to just leave my engines alone once I have them running well.
Steve
Aug 27, 2008, 05:49 AM
Nemo in a blender
Connexxion's Avatar
I use the pinchtest for the LSN.
HSN test is done by holding the plane vertical with it's nose straight up at WOT.
Aug 27, 2008, 09:01 AM
Pinch test is good for both high and low ends. It reacts faster for high end but the principles are the same. As others have said, the Tach is best for high end stuff especially four stroke engines. The thread at the top of this topic is well worth reading and using.
Cheers,
Chip
Aug 27, 2008, 01:44 PM
KMR
KMR
What's the thinking when holding the plane vertical for the high end mix? What do you listen for?
Thanks KMR
Aug 27, 2008, 02:53 PM
Zor
Zor
Connexxion,
But you are not explaining how you can tell if it is properly set.
In fact I think someone else is asking.
I do not wanr to finish your post for you. That would be impolite on my behalf.
Zor
Aug 28, 2008, 10:04 PM
-insert witty saying here-
Hemikiller's Avatar
Originally Posted by Zor
Connexxion,
Zor
LOL, I'll do it...
...holding the plane vertically at WOT, if you pinch the fuel line, the rpms should -increase-. If they drop off, the HSN is too lean. Open the needle a couple clicks and repeat.
Aug 30, 2008, 09:32 AM
I get really paranoid when I have to hold the plane nose up wot. I just do it on the table then go for a fly. If its too lean I just quickly land the plane and richen it up 1/8th turn and test on the table then refly/test. If it is too lean while flying all you have to do is cut the throttle and land. While idleing comming around setting up for landing...the plane is useing the slow idle setting and wont damage the engine. Then again I tend to run just a tiny rich all the time just to be safe. I like to see a smoke trail when I fly.
Jay
Aug 30, 2008, 03:08 PM
Zor
Zor
How is it known?
Jay
Hi skybanker,
A little imaginary situation here _ _ _
I am with you at the field and you made all your adjustments or touch up on the table and you declare ready for a flight.
There you go with a beautiful take off and the airplane is climbing nicely, left climbing turn, leveling downwind about 200 feet and you tell me "that engine is running lean, I better land and make it a little richer".
I then ask you "what make you say it is too lean ?"
What do you answer me ?
Zor
Aug 30, 2008, 09:44 PM
Originally Posted by Hemikiller
LOL, I'll do it...
"Pinching" the fuel line with the engine WOT while holding the plane vertical is not a very good idea. In fact its a good way to lose a few fingers or a hand when it suddenly slows down.
It goes like this: tune the high end to peak rpm on the ground with the plane sitting horizontal. You find the peak rpm by turning the needle in too far so that the rpms start to fall off----which means you found the lean point. Now back the needle out about 3/4 turn from the point of being lean and then hold the airplane vertically and see if the rpms increase. And don't just hold it there vertically, do it like recycling a condom and shake the f--k out of it while it is vertical. Once you get "the ear" for a properly tuned engine you'll find its no big deal to do.
Rube
Aug 31, 2008, 08:51 PM
T.L.A.R. eng
Rube
Don't want to be anywhere around during the last bit.
Sep 02, 2008, 06:56 AM
Hemikiller's Avatar
I don't think it's any more dangerous than twiddling a needle with the motor at WOT sitting on the ground. If the plane is too unwieldy, have a helper hold the it up for you. I've been doing this for 20+ years and never even brushed up against the prop. Most of my stuff is 40 size, so it's no chore to hold it by myself.
Wanted looking for high end yamaha piano keyboard Eeeeky Non R/C Items (FS/W) 4 Aug 09, 2007 06:46 PM
Discussion Lipo for high end helicopers ? oded mazor HobbyKing 4 Dec 06, 2006 11:53 AM
Need Suggestions for High end Trex Setup Z400Flyer Mini Helis 2 Dec 11, 2005 04:00 PM
