This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
Aug 09, 2008, 04:34 AM
Jack Crossfire's Avatar
Metal gears can break
Found the gyro bandwidth was doubled during the PWM rewrite, so set it back to its original value & got back to very similar gains as before the rewrite.
ANALOG_LOWPASS 1
Got all the way to the following gain:
CYCLIC_DAMPING 28
With this, if U push the stick over & snap it back she enters roll oscillation but recovers.
CYCLIC_DAMPING 32
is actually stable if she's not pushed. Snapping the stick over causes growing roll oscillation. So still evidence of noise adding slight stability.
Next, began adding nonlinearity to the feedback.
CYCLIC_DAMPING 24
CYCLIC_CURVE 128
Seemed to react the same. Unfortunately this was all we got before the aft cyclic servo failed again & she flung 30 ft across the ground. It may either be metal gears wearing out or gimbal lock with our crazy pushrod geometry. No-one is anxious to have a 3rd loss of control to find out.
Yaw damping seemed to oscillate the same whether 16 or 8. Need to try reducing yaw bandwidth.
can you get metal gears for the hs 55 servo? jeff262 Hitec/Multiplex USA 6 Jan 06, 2004 05:54 PM
I can break anything (IFO). Andy W Parkflyers 12 Oct 01, 2002 08:07 PM
Lightest Servos with Metal Gears? Jerry Rose Radios 3 Aug 03, 2002 08:30 AM
FS: Zagi-stuff (metal gears, 4-cell NiMH, servo savers) thwang99 Aircraft - Electric - Airplanes (FS/W) 1 May 10, 2002 10:45 PM
Metal gears required for all 4 servos for Magic 3d? Balin Sport Planes 3 Nov 14, 2001 11:49 AM
