Mar 23, 2009, 12:48 PM
Originally Posted by 19Graham91
Hi Guys, I am going to be building one of these soon, what is the best CG position for it?
thanks
Graham
I hope that you get one built that works.
Evidently Gelei Imre's maiden did not go well.
He never came back with a report.
I would like to build one too, but have never seen a successfull scratch built one yet.
Tim
Mar 23, 2009, 03:09 PM
19Graham91's Avatar
thanks Tim, I am just finishing off the plans, getting it cnc cut and then will have a play with one and get it built.
Will have a play around with the CG and will hopefully eventually get it right, may take a few attempts
Will be sure to keep you posted with my progress
Graham
Mar 24, 2009, 02:28 PM
Originally Posted by frank48
Hi
By special request here are the a4 tiled plans ...
Cheers,
Frank
would you be able to make a tiled set for letter format?
It would really be appreciated.
Thank you.
Matt
Mar 24, 2009, 02:38 PM
Gelei Imre
Gelei Imre's Avatar
Tim
Hi,
because I did'nt maiden flight yet, because here is all day is windy. And a was wery busy, wih other works. When I will to fly it, I will make report, and video too.
Cheers
Mar 25, 2009, 09:43 AM
Went to mow a meadow
frank48's Avatar
Thank you.
Matt
Added to first page
Frank
Mar 25, 2009, 07:57 PM
Added to first page
Frank
Thanks a million Frank!
Mar 25, 2009, 08:32 PM
NewFlyer
KenChin's Avatar
Anyone willing to share their technical setup? I think i might give a go at this one...
Mar 26, 2009, 03:59 PM
Gelei Imre
Gelei Imre's Avatar
Hi Ken,
here is my config:
My motor is Keda 20-34:
http://www.kd-motor.com/a20.htm
Prop: 8X4
Esc 10/12A
Servos: 2XTP90
Battery:2s900mAh-s Lipo
RX: Yeti Rex7mpd
Mar 27, 2009, 01:05 PM
I built one from plans by Gelei Imre. I made it out of 3mm blue foam (dow protection board). It is very light and fragile, but works. I haven't figured out good center of gravity point yet, but I got it flying (after lots of trying, hehe).
I use 15T/24G cdrom-motor with 3S 460mAh lipo battery. 7x3.5 prop, two 6g servos, 9g receiver, Turnigy plush 10A speed controller (9g) and few bamboo skewers as reinforcement. AUW is ~200 grams.
I'll also post a video whenever I get it flying nice.
Mar 28, 2009, 03:52 AM
19Graham91's Avatar
Hi guys, thanks for the info.
I will hopefully be building mine over the weekend, going to cut from 3mm depron, and wil be using a 70W motor (gws 8x4.3), 10A speed controller, 2 9g servos, 8g receiver, and 450mAh 2s packs
Hoping to get an all up weight of about 150g, but see how we go, also going to be trying a few things with the motor assembly and how it moves with the elevator.
will post pics when I can
Mar 28, 2009, 04:11 AM
To Build? or Build Another?
genetix's Avatar
I really want to build one of these but i think im gonna tweak the design a little... I like the raid truck pic posted earlier, so maybe that style with a large fin on top as the elevator... and something needs to be done about that front side... it seems way to unforgiving on hard landings... Possibly a carbon bracing rollcage?? Hmm...
And now for the real question... WHICH PROJECT AM I GONNA DO THIS WEEKEND?!?
Mar 28, 2009, 08:17 AM
I sliced some 5mm EPP today and will make another truck from same plans. I'll post pictures later today.
Mar 28, 2009, 08:50 AM
NewFlyer
KenChin's Avatar
3mm Depron sounds very fragile on this Truck. Gotta be a soft landing. We only have the 5mm depron here, in Malaysia. I've scratch built one, but has done done anything on the electronics as i have difficulties in the Steering mechanism.
I think i will deal away with the old one, and start on a new truck based on the plans available now. But, these has to be done after my 36" Foamie Geobat. It's crazy to have 6 servos on a Foamie!
Mar 28, 2009, 11:20 AM
19Graham91's Avatar
Had a go at putting it together, found a few issues with some slots etc and some pieces, so going to have a mess about with the files to get everything fitting correctly.
Hopefully get it built tomorrow once the new parts are cut, thinking of a scheme I can airbrush on in the mean time! just want something simple..... any ideas?
Going to have a play with the motor mount, will be cutting it from some fibre glass and will have it pivotting, may try a separate servo for elevator and motor and mix them together, until I have flown it and got it setup right.
As for the construction, I am using 3mm depron for the weight more than anything, want it to be as light as possible, I fear that if its too heavy it will be a pig to fly!
Will be using plenty of bracing with extra depron and carbon fibre where needed, but hoping to integrate a lot of it in to the depron.
Not going to bother with steerable wheels either, I don't plan on using it on the floor much
will keep you updated
Mar 28, 2009, 04:41 PM
Gelei Imre
Gelei Imre's Avatar
Some pictures about motor mount making with adjustable thrust:
Discussion Why don't women like RC flying? emaij Life, The Universe, and Politics 202 Feb 05, 2014 10:02 PM
For Sale Fly Wheels Xpv Rc Plane Car W/ Leds For Night Flying, Battery & Charger Brand New minimotomods Aircraft - Electric - Airplanes (FS/W) 0 Jan 08, 2007 12:35 AM
RC - Flying Fish Jurgen Heilig Power Systems 7 Oct 10, 2001 03:44 AM
12" RC Flying Insects? - The House Fly Mario Electric Heli Talk 1 Jun 18, 2001 01:04 AM
Other types of RC flying model gzmtyl Electric Plane Talk 3 May 30, 2001 04:39 PM
