Thread Tools |
This thread is privately moderated by worldwide, who may elect to delete unwanted replies. |
Trader Rating: 0
For Sale
25-Amp Pro Brushless ESC by E-flite Brand New
Brand New 25-Amp Pro Brushless ESC by E-flite , Bought a Stryker f27c Parkzone and do not need the Esc............$35.00 inc shipping!.... does not come with connectors !
5-Amp Pro Brushless ESC Key Features Up to 25 amps continuous current with proper air flow Finned heat sinks for both the motor drive mosfets and dual BEC regulators to support up to 4 sub-micro servos Programmable motor braking Safe power-arm mode prevents accidental starts Programmable low voltage cut-off with settings for 2-cell Li-Po (6V), 3-cell Li-Po (9V) or 70% of battery starting voltage Programmable throttle input range (1.1ms–1.9ms or Auto Select) Auto motor shut down if signal is lost or there is interference Programmable timing—2 user selectable ranges for use with a large variety of brushless motors Pre-wired connectors—E-flite EC3 on battery input and 3.5mm female gold bullets on motor output leads Soft start Overview This controller has been designed for use in radio control aircraft and to support continuous currents of up to 25 amps when using 2-3 cell Li-Po battery packs and up to four sub-micro servos. The ESC features a lightweight plastic case, with exposed, finned heat sinks for both the motor drive mosfets, and unlike many controllers, the BEC regulators give you a more reliable and powerful power supply for your servos. Specs Brake:Yes - Programmable Continuous Maximum Current:25A Input Connector Types:16 AWG with E-flite EC3 Connector Output Connector Types:16 AWG with 3.5mm Female Gold Bullet Connectors Momentary Peak Current:30A (15 sec) Dimensions (WxLxH):28x48x11 mm (1.1x1.9x.4 in) Weight:32g (1.2 oz) Cells w/BEC:2-3S Li-Po or 6-10 Ni-MH/Ni-Cd |
Thread Tools | |
Similar Threads | |||||
Sold | 25-Amp Pro Brushless ESC by E-flite | CGReload | Aircraft - Electric - Power Systems (FS/W) | 0 | Jun 23, 2008 02:47 AM |
Sold | 25-Amp Pro Brushless ESC by E-flite | Dynomike | Aircraft - Electric - Power Systems (FS/W) | 3 | Jun 03, 2008 05:06 AM |
For Sale | E-Flight 25-amp Pro Brushless ESC | gotwakesvl | Aircraft - Electric - Power Systems (FS/W) | 5 | Jan 18, 2008 06:26 PM |
Sold | E Flight 25 amp pro brushless ESC | Joe in Dublin | Aircraft - Electric - Power Systems (FS/W) | 0 | Jan 11, 2008 08:20 PM |
For Sale | E-Flight 25-Amp Pro Brushless ESC | Quigs | Aircraft - Electric - Helis (FS/W) | 0 | Dec 09, 2007 04:06 PM |
