Feb 14, 2016, 05:04 AM
Closed Account
Originally Posted by derk
Woah woah woah, is that a micro carbon bagged wing with ailerons??
Yes. They really exists.. They sit in my garage.. I will consider making a set to be viewed at the Getty Art Museum, if appropriately compensated...
I think it's the work of Mattfly that lead me down this path after buying the whip it..
Feb 14, 2016, 08:36 AM
Weltherrschaft will be mine
Micro folder for not too high rpm ( use it on a 10gramm 3000kv on 2s) is the umx radian prop its 140*70mm.....
tapered corbon tubes are available through old fishing rods or thru the corresponding stores
Feb 14, 2016, 08:37 AM
and the prop is really light, below 2 gramms.....
Feb 17, 2016, 10:40 AM
B A bay B E be B I bicky bi
micro_builder's Avatar
Originally Posted by RobertTHaas
Hi Guys! Just noticed this forum.. Here are some Micro DLG gliders I have been developing..
2 DLG's V1 and V2 main forum Link..
Aires V1
Aires V2
A video of Aires V1 second set of test flights..
https://www.youtube.com/watch?v=Aj_U...ature=youtu.be
Very nice!
Mar 02, 2016, 03:22 AM
TheyreComingToTakeMeAway!
derk's Avatar
so this is my first attempt at a lost foam nose pod. it's rather flexible mostly because the first layer of glass did not set up right from my mixing the epoxy with alcohol to thin it
next time i will try and use some good epoxy not the walmart 5 minute special
so on the 700mm glider, the AUW with a 180mah cell is 28 grams. but i also rebuilt the front with some carbon rails around the servos and battery, so it should be nice and strong compared to the first balsa one.
Mar 02, 2016, 07:48 AM
cranium accessories
dustn's Avatar
If you didn't this time, next time cover the foam with packing tape before glassing! This makes it much easier to get the mess out!
Micro Hlg ???????? AIR MOVER DLG Hand Launch Gliders & F3K 14 Aug 04, 2009 09:28 PM
bug micro hlg f/s ERGO60SX Aircraft - Electric - Airplanes (FS/W) 8 Nov 27, 2002 10:01 PM
Micro HLG Conversion Q's RB Scratchbuilt Indoor and Micro Models 1 Nov 10, 2002 10:44 PM
Anyone Fly the DAW Dragonette Micro HLG??? webguyjv Electric Sailplanes 9 Feb 20, 2002 01:44 AM
Albatoss micro HLG? cheapflyr Electric Sailplanes 6 May 26, 2001 11:52 AM
