New Product
Spektrum AR500 5 channel full range receiver
Looks like Spektrum is coming out with a new full range 5 channel receiver...
![]() ![]() http://www.horizonhobby.com/Products...rodID=SPMAR500 |
Interesting, but are they trying to confuse us? Why not keep it consistant and call it the AR5000? I count 7 rows of pins. I hope there is alittle more to it than, just the one longer antenna. Is that why it only gets two zeros, because its not a real two rx full range rx?
-Kwok |
Very interesting, it looks as though Spektrum has taken a page from Futabas method of achieving antenna diversity.
The "longer" antenna is a coaxial feed arrangement with the active antenna element being the last 30mm where the shield has been removed. A lot simpler arrangement for installation in tight quarters than satellite receivers. Pete |
Yet they still want you to cram in those top pin connectors
somewhat akin to th original 6 channel DX6 6000rx (long whisker )
likely developed for those glider fans amongst us. I used a different approach - but I can see where this may be popular. anyway you get the same features as the others - Model Match ec., which I really like. |
so... a five channel that is more expensive than the AR6000? Not sure what the point of that is unless it's really small or light, even then, the pins are on the top so it's not as convenient as a "end-pin" type.
my 2 cents ~irish |
You're always so fasst to rub it in arn'tcha ![]() I have been very pleased with the performance of my fasst stuff, but they are utterly clueless as to marketing ![]() Pete |
Guys. by just looking at the Picture..... I guess, this is just a Regular AR6100 single Receiver with just an extention antenna........they just make the Antenna longer so that you can easily mount it outside the fuseledge of the aircraft.
Hope somebody can make a full review of this latest receiver, and see how it actually performed.......compare to the AR6200 or AR7000. for a peace of mind, I would rather use the AR7000. |
Well, the AR6100 only has one antenna (yes, ith has two ends, but it is ONE antenna
![]() Now if they made both antennas the Fasst way, this would actually be the first Spektrum reciever being able to work in a CF fuselage without theoretical problems ![]() But a good first step into the right direction. Too bad they made the Fasst mistake of not offering end pins. |
I suspect they hid two rx in that little box- won't know tilI get mine the concept tho is appealing for extremely slender/tight fuselage requirements Iwould guess-- a really good arangement would be the short antennea -out side lower portion of fuselage - the longout and buried along upper wing panel. My favorite diversity setup is one antenna on top of model -the other on belly. |
The 6200RX was $70 from toddsmodels and $80 on Horizon's site. So presumable this one is $60 on horizon's site so will $50 at other places. It's $20 less then the current cheapest full range Spektrum RX. A lot of us fly planes that are only 4 channel or 4 channel with 2 channels for aileron so only need a 5 channel RX. I have a DX7 but have just been buying 6200's since they were cheaper then the 7 channel RX's. If they work and they probably will I will buy these instead next time I need new RX and save the few 6 and 7 channel RX's I have for the rare plane I build that atually needs that many channels. |
It is very strange that the case looks like it has a cut out for the remote receivers. Probably just the AR6200 case and the same main board for the mock up. Makes me think that this will have a different RF chip in it than the AR6200/AR6100 since it claims two receivers, and I know that there isn't room for a second chip (unless they stack them).
Thread Tools | |
Similar Threads | |||||
For Sale | Brand-new Spektrum AR6200 Full Range Receiver $72 shipped | quar | Aircraft - General - Radio Equipment (FS/W) | 2 | Mar 17, 2008 07:24 PM |
Sold | Spektrum 6200 full range receiver | cryhavoc38 | Aircraft - General - Radio Equipment (FS/W) | 0 | Nov 16, 2007 10:44 AM |
Jeti REX 5 plus - Full Range Receiver ? | glidingon | Radios | 2 | Jan 12, 2005 11:47 PM | |
Small full range Receiver needed?? | Steve H. | Radios | 7 | Dec 27, 2002 01:02 PM | |
Looking for light weight/full-range receiver | Danny Van Hoecke | Electric Plane Talk | 3 | May 03, 2002 07:23 AM |
