This thread is privately moderated by JimDrew, who may elect to delete unwanted replies.
Sep 12, 2016, 12:09 PM
Updater 55
This updater limits the SBUS input from going beyond the specification thresholds.
This update also adds an experimental input mode for the primary input (ONLY). The 8th input mode is now inverted SBUS. So, inputs 2 and 8 are SBUS, with 8 accepting SBUS with an inverted polarity.
http://www.xtremepowersystems.net/xdp/updater55.exe
Sep 13, 2016, 07:56 AM
If it has wings it will fly...
ckleanth's Avatar
Originally Posted by jimdrew
this updater limits the sbus input from going beyond the specification thresholds.
This update also adds an experimental input mode for the primary input (only). The 8th input mode is now inverted sbus. So, inputs 2 and 8 are sbus, with 8 accepting sbus with an inverted polarity.
jim the link points to v 5.4
Sep 13, 2016, 10:49 AM
Thanks... fixed!
May 26, 2017, 03:45 PM
X24 - Updater 1.4
Updates X24 to firmware v1.4.
Changes AutoMatch to have 12 groups, matching a single slave (instead of 5 groups matching up to 3 slaves). Fixed a bug where controls for D1 and D2 were backwards. Improved AutoMatch time dramatically!
http://www.xtremepowersystems.net/X24/X24-updater14.exe
Jun 01, 2017, 02:38 PM
Updater 56
Fixed issue with X10+ servo outputs being shifted during a failsafe condition after a failsafe channel was set to 'OFF'.
http://www.xtremepowersystems.net/xdp/updater56.exe
Jun 20, 2017, 11:27 AM
X24 - Updater 1.5
Updates X24 to firmware v1.5:
Corrected problem with SBUS2 input.
Changed LED handling to use DMA instead of bit-banging.
Added ability to reset the EEPROM from the emergency Serial Link startup by
holding SW2 for 10 seconds at power up.
http://www.xtremepowersystems.net/X24/X24-updater15.exe
Jan 21, 2018, 03:51 PM
X24 - Updater v1.6
Updates X24 to firmware v1.6:
Changed JETI UDI mode to output a straight channel map, instead of following
the UDI spec. Also note that 14ms needs to selected for the frame rate with UDI.
http://www.xtremepowersystems.net/X24/X24-updater16.exe
May 07, 2018, 07:42 PM
Updater 57
Fixed issue with OpenTx v2.1.0 and later working with the JR module.
http://www.xtremepowersystems.net/xdp/updater57.exe
May 11, 2018, 12:02 PM
X24 - Updater v1.7
Updates X24 to firmware v1.7:
Removed JETI UDI support from XBUS Mode B code.
Added new code for handling JETI UDI protocols. Setting input mode to
JETI UDI automatically recognizes UDI12 and UDI16 protocols, and even
supports switching between UDI12 and UDI16 on the fly.
Spelled SRXL correctly!
Added ability to reset defaults for a JETI channel map.
Corrected channel mapping for D1/D2 and E1/E2 with default Futaba channel map.
Changed Power Off from menu to not allow a power off when match power is
the power source.
Removed 2nd page of Information screen (it was redundant).
http://www.xtremepowersystems.net/X24/X24-updater17.exe
May 12, 2018, 12:28 AM
Updater 58
Added support for JETI UDI to the X10+ V2. This is not supported with the original V1 hardware. The new manual describes the change to the input modes for selecting the UDI protocol. The JETI UDI setting automatically detects UDI12 or UDI16.
http://www.xtremepowersystems.net/xdp/updater58.exe
May 26, 2018, 02:49 PM
X24 - Updater v1.8
Updates X24 to firmware v1.8:
v1.8 - 05/26/18
Added option to have LED either OFF or ON when a power-off occurs (in SWITCHES menu).
Increased switch debounce time to 100ms minimunm when using NONE for the switch delay.
Fixed backing up from Main Menu to Channel Info when exactly 12 channels are being used.
http://www.xtremepowersystems.net/X24/X24-updater18.exe
Jun 17, 2018, 01:54 AM
X24 - Updater v1.9
Updates X24 to firmware v1.9:
v1.9 - 06/14/18
Changed power off routine so that Match Power input has to be >4v before the power off is disabled.
Added Diagnostic menu option to the System menu.
http://www.xtremepowersystems.net/X24/X24-updater19.exe
Jun 18, 2018, 12:09 PM
Link takes me to X24-updater18.exe
Jun 18, 2018, 09:05 PM
Thanks! Fixed!
Oct 02, 2018, 11:33 AM
X24 - Updater v2.0
*** NOTE *** IF YOUR FIRMWARE IS OLDER THAN V1.9, YOU MUST UPDATE THE X24 TO FIRMWARE V1.9 *BEFORE* YOU UPDATE IT TO V2.0!
Updates X24 to firmware v2.0:
v2.0 - 09/25/18
Added support for selecting up to 32 channels.
Added support for JETI ex-Bus protocol.
Added auto-repeat for channel number input.
http://www.xtremepowersystems.net/X24/X24-updater20.exe
