May 14, 2011, 01:37 AM
Coenraad's Avatar
Thank you all very much for the replies. I can't wait to get her out today
May 14, 2011, 05:17 AM
QuAd FaNaTiC
Razors edge 29's Avatar
Well I rebuilt my Trojan
Doesn't look the best but it flies
Will have to eventually get new airframe and do custom
May 14, 2011, 08:58 PM
kylewoody's Avatar
Hey guys,
Refinished my old worn out Trojan. Had it since '08 and decided to give her an overhaul. Believe it or not, it's only cosmetic - still flying on all original equipment! Stock motor, ESC, servos, every piece of the airframe. I have burned through my Parkzone battery's cycle life though, and moved on to G Force 1800s.
Thought you guys might like to check it out, I also did a little mini how to on my blog.
Kyle
May 14, 2011, 08:59 PM
SMCLEODVT's Avatar
that looks awesome IMO
May 14, 2011, 09:05 PM
Not Crashing = Not Flying
Cody S's Avatar
That is amazing! I read your blog too, outstanding job!!!!
May 14, 2011, 09:10 PM
It's just a plane.
ZackJones's Avatar
That is one GREAT looking T-28. Way to go!
May 14, 2011, 10:17 PM
QuAd FaNaTiC
Kyle
it looks fantastic
May 14, 2011, 10:56 PM
kylewoody's Avatar
Thanks guys! I love the way the aluminum finish came out. It's not perfect, but when it comes cruising by at a scale half throttle and into a slow roll it really is convincing seeing the sun glint off the plane!
Kyle
May 14, 2011, 10:58 PM
Advanced Heli Collector
9sec240's Avatar
Kentucky Chrome!!!! Very nice!!
May 15, 2011, 01:34 AM
manual flying apologist
Adidas4275's Avatar
so I finally got my watt meter from HK so i figured I would post my results:
All test were done at sea level
Motor: E-Flite Power 10
ESC: Turnigy Plush 60A Timing Low
Battery: Tunigy 30C 2200mah battery that was 90% full
Props:
9.5x7.5 380W @ 34A
9x9 385W @ 35A
10x7 369W @ 32A
10x10 470W @ 42A
I have a 11x7 that I need to test out.
It really surprised me that the 9x9 was so close to the stock T-28 prop and that the 10x10 was pumping 470W @ 42A
That is a lot of power.
I have a Turnigy SK 35-36 1400KV motor coming that I plan on testing out and then probably using in a PK P-51 that I am going to build, since the 3536 is going to be lighter than the Power 10.
I decided to do a straight cut for my flaps and us nylon hinges on the bottom of the flap. It looks cleaner on the top of the wing and provides more travel for the flaps since I can mount the control horn closer to the edge of the flap. I added a servo slower to the flaps and will probably cut them into my real wing (not my old beat up one) over the next week.
Then it will be time to install my retracts (which got here today from HK as well)
May 15, 2011, 02:29 AM
Coenraad's Avatar
That was one awesome looking T28. I have allot of silver on mine too, and yeah man, feals great to see the sun glint off it. Well done! I really like the way the silver came out, looks allmost polished .
Ps a question about props:
I took a 10x6 prop for my Power 15, but someone told me it is a nitro/fuel prop as it is thick and hard. And that those thin flimsy props are electric props.
Will the nitro prop damage my settup in anyway? I took the thick prop since they don't break that fast.
May 15, 2011, 07:32 AM
I can fix it.
nageotte's Avatar
Totally Awsome T-28!
I just finished a flying wing from crashtesthobby.com and it included a large roll of clear laminate that is sticky but still irons on. Paint adhears to it very well. I think it would lend itself to this purpose really well. Check it out. And tell Lee I said, "Hi."
Jim Nageotte
Kyle
May 15, 2011, 09:39 AM
Coenraad's Avatar
Adidas, how do those nylon hinges look? i am thinking of putting in flaps as well.
Here is a pic of how i altered the cowling to make the p15 fit.
May 15, 2011, 11:58 AM
QuAd FaNaTiC
does anyone know if you can just buy the firewall for T-28?
mine is screwed
May 15, 2011, 12:03 PM
Adidas4275's Avatar
Nope new fuselage for you.
I have reinforced my firewall with hot glue behind it and it seems to do well.
You might be able to rebuild it with plywood
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6538 Nov 05, 2021 05:01 PM
ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 896 Mar 06, 2021 10:17 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2603 Mar 21, 2020 03:12 PM
Sold Parkzone T-28 Trojan, 480 960kv Motors (2) Joe in Dublin Aircraft - Electric - Power Systems (FS/W) 4 Jan 17, 2008 02:34 PM
Wanted Parkzone T-28 Trojan Scale-Hobbies Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
