Simple Delta... a quick build "prop on the front" delta - Page 5 - RC Groups
May 25, 2008, 12:45 PM
He Did WHAT? "AGAIN?"
Kosh28's Avatar
Heres some video of this done 3 years ago
http://video.google.com/videoplay?do...39563234364529
Note: The CG is NOT correct in the photo and its between 5" to 6"
May 25, 2008, 12:50 PM
D'oh.. Dumb Left Thumb
dekan's Avatar
Thanks for the video Kosh..... I knew there was one somewhere....
The picture should help make things even clearer... But I won't recommend the the CG measurement as being a good start point....
May 25, 2008, 01:38 PM
DreamArcher's Avatar
Nice.
May 25, 2008, 06:34 PM
Use whatcha got!
msmith's Avatar
Been awhile since I've had time to build 'anything' at all...
This looks like fun though. I'll have to locate some extra lightweight foam in the shed.
Will stay away from EPP for the vertical though... The last EPP vertical on a fast plane wound up twisting and producing a weird corkscrew effect (EPP Skyray)
-mike
May 25, 2008, 07:10 PM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Only above 50 mph ...
Latest blog entry: Lost plans
May 26, 2008, 12:41 AM
flyin' fool
goldguy's Avatar
Here's the same design, a free plan for Depron from RCM&E a few months back, only with an undercambered reflexed airfoil. Supposed to solve any pitch problem. Problem is bending EPP to an airfoil shape, it has to be hot wire cut.
So, I think I'll try kosh's flattie orginal in a 20" span for a 1500kv Blu Wonder and give that a try.
May 26, 2008, 01:43 AM
Use whatcha got!
msmith's Avatar
Why would I fly slower than that?!?
heh
May 26, 2008, 01:55 AM
dekan's Avatar
Why not build a Hybrid.. FFF or Depron wing, Epp for the rest of it...
May 26, 2008, 04:01 AM
Hi Dekan
Couldn't help myself, made one of these last night. Flew it this morning and went back for more this afternoon. So nice to fly.
Mine is full EPP, BW 1700kv, 1000mah 3's, 7x5 prop.
So quick and easy to build it had me worried, but congratulations sweettttttt plane.
Building another one tonight with a different shaped fuse centre fin just for looks.
The DD is sweetttttttttttttt
Rudolf
May 26, 2008, 04:29 AM
dekan's Avatar
Rudolf.... Great Fin..... next one do the canopy clear and put Bart in it.Lol
Any chance of an underside picy. Where did your Cg come out at?
May 26, 2008, 05:14 AM
Look outside the Square
Boxhead's Avatar
Looks Great Rudes. It Definately is a Sweet Flyer .
Good Aussie design that one Frank . Wont take you long to whip this one up MS. She's corker .
B x
May 26, 2008, 06:15 AM
Thanks Dekan, Box.
Dekan I couldn't get it to fly with the cg at 6", it just hovered and went straight up like a rocket and when I powered up it would blow out and spin. I nearly gave up and then remembered what Box said and rebalanced with the cg at 5". At cg 5" it leaves my hand nearly. The black mark is the 6" cg I just moved things around at the 5" cg and rebalanced.
Any help with a fin design would be great, something weird. I didn't paint the bottom of the fuse on purpose, it makes it look more spacey?
Flying the DD again tomorrow can't help myself. The BW 3000kv with a 4.5 x 4.1 is a rocket on my Mini Bee will let you know how it goes on the DD.
Rudolf
May 26, 2008, 06:31 AM
dekan's Avatar
Ok rudolf.I will make a note # 1 post on the recommended CG start point
Thanks for the underside views.Good luck with the motor swap
May 26, 2008, 06:41 AM
Dekan this one goes with me everywhere. All EPP same running gear but with 1500mah 3's battery. Battery weighs 143g the 1000mah 3's weighs 83g. Will try the bigger battery on the DD tomorrow.
May 26, 2008, 07:02 AM
dekan's Avatar
Wow... do work for Fisher Price in your spare time!
What have you got against propsavers Rudolf!
Looking for info or chart on the park 400 4200 motor for prop size, amps himeros Electric Plane Talk 1 Oct 17, 2005 09:47 AM
Outrunner: Prop on shaft or can? XTheOwl Power Systems 2 Aug 31, 2005 10:46 PM
Question Prop on left or right DD tail? pike Micro Helis 7 Apr 06, 2005 01:42 PM
Can I use a 3 or 4 bladed prop on my GWS Corsair??? Valid8r GWS (Grand Wing Servo) 10 Jan 18, 2005 08:38 AM
prop ? on B50 13s (Kmashima or Ed Lyerly) rcman Sport Planes 11 Apr 12, 2003 03:21 AM
