Simple Delta... a quick build "prop on the front" delta - Page 204 - RC Groups
Aug 11, 2017, 03:01 PM
flyin' fool
goldguy's Avatar
Also........................ https://flyingfoam.com/product/epp-sheets/
Aug 11, 2017, 03:09 PM
pull up -- PULL UP!!!
There you go...bookmarked. Thanks.
Aug 14, 2017, 09:59 PM
flyin' fool
goldguy's Avatar
Had a blast in howling winds this weekend. Added a rudder to ramp it up, .5 ounce more RTF. Dropped the prop to a 6X4, perfect! Had to fiddle with the motor's side thrust angle.
Feb 04, 2018, 06:04 AM
flyin' fool
goldguy's Avatar
New setup..................
Tried an APC 7X3.8 SF prop on 2S Gens Ace 520s and shed the extra half ounce. (9.8 amps / 77 watts in) AMAZING. Better than before. A tiny loss of speed at WOT, but the same ballistic vertical. Now with the extra thrust and bigger diameter prop it's the best of both worlds, mild to wild, as it now flies super slow.
Was out today flying in the wind on the side of a mountain and had a blast flying down below myself and shooting up the ridge for touch n' goes off the tall grass on the edge of the ledge.
Only had one retrieval.
Feb 12, 2018, 02:56 AM
flyin' fool
goldguy's Avatar
Beautiful day here today, so off to the slope. Thought I'd see what the SD would do. I was actually able to kill the throttle and keep it up, the lift was that good.
Well, until .....................
Feb 12, 2018, 10:02 PM
Gregco10's Avatar
Simple Delta with Hobby King Orange gyro Greg006 end cuts off (6 min 1 sec)
This plane of course does not need a gyro but I stuck one on anyway to mess with gains. It was ok but I didn't really see a benefit enough to keep it.
Feb 14, 2018, 06:25 AM
Reap the wild wind
headlessagain's Avatar
Someone call "Combat" Frank? It's just a flesh wound but the ASW tail doesn't look too good. My flying buddy snapped the tail off of his in a less than perfect arrival so would probably benefit by some carbon strips up each side
Feb 14, 2018, 09:45 AM
flyin' fool
goldguy's Avatar
Seems everything we launch out is combat fodder around here.
Looking for info or chart on the park 400 4200 motor for prop size, amps himeros Electric Plane Talk 1 Oct 17, 2005 09:47 AM
Outrunner: Prop on shaft or can? XTheOwl Power Systems 2 Aug 31, 2005 10:46 PM
Question Prop on left or right DD tail? pike Micro Helis 7 Apr 06, 2005 01:42 PM
Can I use a 3 or 4 bladed prop on my GWS Corsair??? Valid8r GWS (Grand Wing Servo) 10 Jan 18, 2005 08:38 AM
prop ? on B50 13s (Kmashima or Ed Lyerly) rcman Sport Planes 11 Apr 12, 2003 03:21 AM
