May 18, 2008, 08:47 PM
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
Help!
What pan-tilt do u recommend
Hi,
I'm building my first FPV with a Easy Glider E and what pan-tilt do u recommend for this setup.
Thanks for the help
May 18, 2008, 10:16 PM
I have both systems from Range video
Depends what you want. the pod range integrate better to each plane. the pandora is really good too, but need more clearance, and can be used with different planes. on an easyglider, you are going to wreck the aero profile. you might be better off making a custom one with just pan.
May 18, 2008, 10:34 PM
G-unit's Avatar
Thanks jbourdon
What online store do you recommend Rburn99 Beginner Training Area (Aircraft-Electric) 13 Aug 18, 2004 03:46 PM
What gearbox/prop, do you recommend? tdavis Parkflyers 4 Apr 26, 2004 10:02 AM
What power system do you recommend Agfly Power Systems 5 Mar 13, 2004 04:43 AM
What electric connectors do people recommend for a plug in wing tip? Michael Heer Thermal 6 Sep 13, 2002 05:21 PM
RE Simple 400; do u recommend... emaij High Performance 7 Jul 25, 2001 11:43 PM
